    Doom and Doom 2 40fps?
    doom
    21 Posts 5 Posters 8.0k Views
      retronerd
      I thought that Doom would run at 60 fps? im using an Raspberry Pi 3 with the latest retropie.
        edmaul69
        If running it at 60fps is anythink like another old first person shooter that was released on the xbox 360 then i wouldnt want it too. I dont get sick playing first person shooters but them changing that game being changed from the original 30fps to 60fps it moved so fast i wanted to barf my brains out playing it.
          retronerd @edmaul69
          @edmaul69 said in Doom and Doom 2 40fps?:
          I was asking if it should run in 40 or 60fps not how you feel;)
          • Solid OneS
            Solid One
            Are you using lr-prboom? Try running Doom with another sourceport, such as zdoom, crispy-doom or chocolate-doom.
            I'm using zdoom here and I'm quite satisfied with the results:
            • Original MIDI music fully supported (no need to convert MIDI to MP3);
            • Controller support, with axis bindings. You can use a Xbox360 controller and map left analog to moving and right analog to mouselook;
            • Supports Doom, Doom 2, Heretic, Hexen and Strife;
            • Supports great mods such as Brutal Doom and RGH (Real Guns Hardcore).
            I don't know if you'll get 60fps, but at least you'll find more advantages on zdoom, comparing to other sourceports.
              edmaul69 @Solid One
              @Solid-One in another thread i posted how to use the dpad and both analogs in lr-prboom. I wish the keyboard and mouse worked in it. For zdoom do i need a .sh file? If so can you post the contents of one? Not one with mods since the dooms, hexenen/heretic and strafe official releases is all i plan on using. Does it support mouse and keyboard? I feel that lr-prboom is unplayable because it has no keyboard support which means it is lacking half the needed controls and they arent on the controller.
              • Solid OneS
                Solid One
                I followed steps from here:
                https://github.com/retropie/retropie-setup/wiki/Doom#how-to-launch-doom-iwads-and-mods-pwads-from-emulationstation-using-zdoom
                Just ignore the "Darkest Hour mod" part. You can use these steps to create the .sh file. I have a couple of them on my RPI, running both original games and games w/ mods.
                And yes, zdoom accepts keyboard, mouse, joystick and probably even touchscreen. It works just like desktop versions.
                The only con I have is: I can't navigate through menus using only a joystick. I need a mouse and/or a keyboard for that task. I can't exit zdoom directly from joystick either. The workaround is having a keyboard and/or mouse nearby, everytime you wish to play zdoom.
                  edmaul69 @retronerd
                  @retronerd if you want 60 fps it is changed in the general setting in doom itself. A little too fast for me. 35fps is the minimum and that is way too slow.
                    retronerd @edmaul69
                    @edmaul69
                    where do you mean? in the emulator i run doom/doom2?
                      edmaul69 @retronerd
                      @retronerd in the actual game. Go into the doom games settings and change it. all the keyboard and mouse functions technically all work except that the retroarch from retropie 4.0 and newer killed the keyboard being functional in systems that use a keyboard other than emulating a controller. In some emulators that have two players you can set the keyboard as player two and it works but then becomes a one player system. But you cant do it with one player systems. I wish retroarch didnt make this change. I would go back to the old retroarch if i could because the keyboard being fully functional outweighs anything they have added in my opinion. Unless the psx updates are tied to the retroarch emulator.
                      • E
                        enderandrew
                        There are several Doom ports listed in the experimental section. I'm curious what the differences are between the various Doom ports available in RetroPie.
                          retronerd @edmaul69
                          @edmaul69 I cant find it?
                          • E
                            enderandrew @Solid One
                            @Solid-One said in Doom and Doom 2 40fps?:
                            I know in Windows I can fully navigate all the menus with a controller out of the box on ZDoom.
                            Is there an equivalent to zdoom-USERNAME.ini in the Linux/Pi port with bindings?
                            Solid OneS 1 Reply Last reply Reply Quote 0
                              backstander @enderandrew
                              @enderandrew
                              RetroPie only officially has two Doom ports: libretro-prboom and (the optional section) ZDoom.
                              (I believe when ZDoom was first added to RetroPie, it was in the experimental section but now it's in the optional section)
                              There's other Doom source ports that will compile on the Raspberry Pi (Like Crispy Doom & Chocolate Doom):
                              https://retropie.org.uk/forum/topic/5614/any-list-for-compatible-custom-wads-in-prboom/24
                              The equivalent ZDoom configuration file:
                              /opt/retropie/configs/ports/doom/zdoom.ini
                              B R 2 Replies Last reply Reply Quote 1
                                backstander @backstander
                                @enderandrew
                                I just look and realized that libretro-prboom is also in the optional section :)
                                My controller worked out of the box as well in RetroPie
                                So @enderandrew when are you planning on getting a Raspberry Pi? :)
                                  retronerd @backstander
                                  @backstander
                                  Cant changé to 60fps?
                                  Where?
                                  • E
                                    enderandrew @backstander
                                    @backstander said in Doom and Doom 2 40fps?:
                                    Absolutely. I try not to spend money on myself at Christmas-time and the past two years there has been a new Raspberry Pi released in February so I'm waiting until then to build my RetroPie.
                                    And if i recall correctly, the original DOOM was designed to run at 35 FPS so getting 40 is about perfect.
                                    On the computer, GZDOOM runs better than ZDOOM. It is a fork of ZDOOM that uses OpenGL hardware acceleration on the GPU as opposed to classic DOOM-style software rendering. I don't know how good OpenGL rendering is on the Pi, so I don't know if there would be benefit to using GZDOOM instead of ZDOOM or not.
                                      edmaul69 @retronerd
                                      @retronerd when you are playing doom, on the main screen where it says things like new game and quit, go into options then general. It is in there.
                                        edmaul69 @retronerd
                                        @retronerd in the game in options general this is the first thing to pop up
                                        • Solid OneS
                                          Solid One @enderandrew
                                          @enderandrew what zdoom version are you using? some bleeding-edge version compiled from source?
                                          If yes, I suspect they implemented controller navigation support recently.
                                          Can you please confirm if, running Strife, you can talk to NPCs with a controller? I got the same problem here with menus on Strife: I can't say yes or no to any NPCs with a controller; only with a Enter keypress on a keyboard, or click in the names with a mouse.
                                          • E
                                            @Solid-One I am running a recent dev build. I think both ZDOOM and GZDOOM got an official release early this year as well. I'll go test NPCs in Strife today.
