    iBuffalo Gamepad Not Detected support required for a complete novice!
    ibuffalogamepaddetected
    5 Posts 3 Posters 2.5k Views
      MissyJ
      Pi Model: 0
      RetroPie Version Used: 4.1
      USB Devices connected: iBuffulo control pad connected via 4 port USB hub
      Controller used: iBuffulo Snes pad
      Error messages received: No Gamepad Detected
      Log found in /dev/shm/runcommand.log (if relevant): ?
      Guide used: https://howchoo.com/g/mti0oge5nzk/pi-cart-a-raspberry-pi-retro-gaming-rig-in-an-nes-cartridge
      File: n/a
      Emulator: n/a
      Attachment of config files: ?
      How to replicate the problem: ?
      I have no experience with raspberry pi but after watching the howchoo youtube vid and reading the guide I decided to give it a shot. It advises no keyboard is required you can just use the controller. Everything was going great until I got to the gamepad screen and it displays no gamepad detected. I plugged the pad into my laptop and it recognised it both with and without the hub.
      I have no idea how to rectify this - any ideas? Please keep in mind I was just expecting to plug and play - I have no idea when it comes to keying commands! I do have a mac keyboard that I can plug in if necessary.
      Thank you
      Jody
      rbakerR 2 Replies Last reply Reply Quote 0
      • rbakerR
        rbaker @MissyJ
        @Miss check the rating of your power supply and also which USB ports you are using. What is in where?
        • rbakerR
          rbaker @MissyJ
          @MissyJ also check https://retropie.org.uk/forum/topic/5845/newbie-usb-controllers-not-recognized-on-initial-bootup
            BuZz administrators
            Make sure you have the controller plugged in the correct USB port.
            You can power the Zero from either, but only one has the USB data pins connected.
            Power is on the right side of the photo.
              MissyJ
              Thank you for the suggestions I will take another look at this tomorrow as the other half has arrived home and it's a secret project for Christmas!
