    USB Joystick doesn't work in emulators
    hidjoystickarduino
    3 Posts 2 Posters 1.6k Views
    • N
      Nauro
      Hello!
      Pi Model: B
      RetroPie Version Used: 4.1
      USB Devices connected: keyboard, usb joystick
      Controller used: Arduino-powered controller from old PS1 joystick.
      The problem is that this joystick works fine in emulation station, but not in any of the emulators or RetroArch configuration.
      There are also no any jsX devices under the /dev/ folder, but there is a mouse device in the system, which is most likely how this device is detected.
      Also, this joystick works in windows like a HID-device without any specific drivers, but even by enabling HID driver in RetroArch config the problem hasn't been solved...
      • rbakerR
        rbaker @Nauro
        @Nauro Please post your retroarch.cfg configuration file and check your power supply can handle the connection of the arduino. What power supply are you using?
        • N
          Nauro
          @rbaker Hi!
          retroarch.cfg I'll post few hours later, when I'll get home.
          Regarding power supply - I use an external 5V 2A USB power adapter and the joystick works fine in Emulation Station, I can scroll pages, select menu items, etc. with it, but it stops working in any configuration tool from RetroArch I try to start.
