    Issues with zero delay joystick
    zero delay
    2 Posts 1 Posters 1.5k Views
    • fhdelrioF
      fhdelrio
      Hi, I am using two zero delay boards for my arcade and everything seems to be working fine, but there is an weird issue.
      The joysticks work fine in the following directions:
      UP
      DOWN
      LEFT
      RIGHT
      UP+LEFT
      DOWN+RIGHT
      But it doesn't work in the following directions:
      UP+RIGHT
      DOWN+LEFT
      This is really anoying: Playing Metal Slug (MAME), if I am walking to the right direction and then aim up, the character stops walking. I thought it was some problem related to the game or the MAME emulator, but the same problem is happening for every other game and emulator (for instance: I tried Earthbound, a SNES game and the character could walk UP+LEFT and DOWN+RIGHT, but it couldn't walk UP+RIGHT nor DOWN+LEFT). This is only happening for both zero delay arcade controllers, this doesn't occur using a Xbox 360 controller.
      Did someone got the same problem?
      Pi model: Raspberry 3
      Retropie version: 4.0.2
      USB Devices connected: Only the controllers
      • fhdelrioF
        fhdelrio
        Hi guys, I just figure out what was wrong. I noticed that the zero delay joystick directionals should be connected in a specific order in the board: UP | DOWN | RIGHT | LEFT and I connected something like UP | RIGHT | LEFT | DOWN.
        I thought the position wouldn't matter because I could set them in the retropie. Probably the board can't handle UP+DOWN and LEFT+RIGHT simultaneously, what makes sense, but when I connected in the wrong positions it wasn't handling UP+RIGHT and DOWN+LEFT simultaneously.
        Anyway, my problem is solved now,
        Thank you
