    Pi3 won't connect to wifi
    wifi wont conn
    5 Posts 3 Posters 2.1k Views
    • Z
      zq8 blazer
      I've been trying to figure this out all day long. I'll try to setup the wifi and I'll enter the correct password. It tries to connect, but won't. I've connected 3 devices to my wifi tonight without any issue. Anyone know what I can do to fix this?
      Pi Model: Pi3 B
      RetroPie Version Used: 4.01
      Built From: Pre made SD Image on RetroPie website.
      USB Devices connected: Xin-mo controller (2nd joystick not yet configured)
      Controller used: HAPP arcade joystick and buttons.
      Error messages received: Cannot connect to wifi
      Guide used: (Mention if you followed a guide): SEVERAL videos, the guide from this website, and a couple others.
      File: (File with issue - with FULL path) n/a
      Emulator: (Name of emulator - if applicable) n/a
      Attachment of config files: (PLEASE USE PASTEBIN.COM FOR LARGE LOGS) Do I need to post this?
      How to replicate the problem: It happens every time I attempt to connect.
        BuZz administrators @zq8 blazer
        @zq8-blazer
        Does your password contain non alpha numeric characters ? Note that the default keyboard layout on RetroPie (assuming you are running from our premade image - I don't know as you provided little information) is UK, so the password may have been typed wrong.
        you can manually check from the terminal sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
        • Z
          zq8 blazer
          Sorry! I thought I read everything, guess I missed that... doh! I updated my first post.
          No, it contains all alpha numeric characters.
          • DorkVonWaterfallD
            DorkVonWaterfall
            i had a simmilar problem because i took another powersupply then i used to...
            PS: some usb keyboards also dont work properly, so if the password is hidden with dots/stars you cant be sure you wrote the correct password
            01001110 01101111 01100010 01101111 01100100 01111001 00100000 01101011 01101110 01101111 01110111 01110011 00100000 01101001 01100000 01101101 00100000 01100001 00100000 01101100 01100101 01110011 01100010 01101001 01100001 01101110 00100001
            • Z
              zq8 blazer @DorkVonWaterfall
              @DorkVonWaterfall said in Pi3 won't connect to wifi:
              Is there a way to show the password to verify it is being entered correctly?
