    "Command not found" when using sselph scraper
    sselph scraperretropie
    11 Posts 3 Posters 3.8k Views
    • O
      Octo_R0ck
      Raspberry Pi 3 Model B with RetroPie 4.1
      When I try to use sselph scraper (even from PuTTy), I get errors.
      Command not found
      Then it comes back immediately to a screen showing "ROMs have been successfully scraped" or similar.
      When I exit the scraper, it shows me:
      Could not successfully install scraper
      Then it points me to a log file
      Does anybody know how to fix this without formatting and starting over?
      • FlaypeF
        Flaype
        Same ! wtf !?
        Help us pls !
        • markyh444M
          markyh444
          I'm sure somebody else has posted an issue with this scraper too and it hasn't installed correctly due to too many requests to the github page. I'm assuming that lots of people have got Pi's and are setting RetroPie up at the minute.
          Retropie in a PSX - Pi3
          O 1 Reply Last reply Reply Quote 1
          • O
            Octo_R0ck
            @markyh444 I think you may be right. Does that error mean there are just too many requests flooding the github server for the scraper to install?
            • O
              Octo_R0ck @markyh444
              This post is deleted!
              • markyh444M
                markyh444 @Octo_R0ck
                @Octo_R0ck I don't know too much about github specifically, but it'd make sense to me. Dunno if there is some kind of bandwidth limitation per user account there either which it may relate to. @sselph could you shed some light on your github page perhaps?
                • FlaypeF
                  Flaype
                  No issue ?
                  • markyh444M
                    markyh444 @Flaype
                    @Flaype Looks like it was resolved on github the other day.
                    FlaypeF 1 Reply Last reply Reply Quote 0
                    • FlaypeF
                      Flaype @markyh444
                      @markyh444 can u post the issue here ?
                      I dont understand how scrap. I used 3 times SSeplh scraper on Retropie Setup and it worked. Now it doesnt work...
                      • O
                        Octo_R0ck @Flaype
                        @Flaype
                        I got it to work from the command line by typing:
                        sudo rmdir -rf ~/RetroPie-Setup/tmp/build/scraper (ENTER)
                        sudo ~/RetroPie-Setup/retropie_packages.sh 823 (ENTER)
                        Then I was able to use the sselph scraper finally.
                        • FlaypeF
                          Flaype @Octo_R0ck
                          @Octo_R0ck
                          Ty dude !
                          Just delete temp files !
