    PSone PI - help
    psone
    8 Posts 4 Posters 3.6k Views
    • FlavioBello11F
      FlavioBello11
      Hi ppl.
      im starting a new project, with a psone, and i want to use the power button of the psone to turn my raspberry on, the psone have a switch for that, and i wonder if i can use the same swith, is one like this:
      alt text - the switch is the white one in the left botton corner of the picture.
      this one:
      Problem is, this switch have 4 connectors, what connectors should i connect to work correctly?
      thanks!
      • markyh444M
        markyh444 @FlavioBello11
        @FlavioBello11 I've done exactly this with a 1st gen PSX. Check out my website in my signature for details on how I got my switch working in the PSXPi section.
        Retropie in a PSX - Pi3
        • FlavioBello11F
          FlavioBello11
          wow, nice!! thanks for sharing bro.
          • lostlessL
            lostless
            I've done a pi project with the psone. 2 of the pins on one the short sides is true on and off. Use a multi meter to determine which ones.
            Good luck with your project.
            • lostlessL
              lostless
              Here's an almost final build of my psone build. Maybe I'll make a video of the final build
              • FlavioBello11F
                FlavioBello11
                WOW, very cool, so you use a board for torn it on and off? there's a name? how can i find one?
                • lostlessL
                  lostless
                  I made that board. It's using project perf board which has solderable pads on the bottom which I soldred the original switch to. The led is also soldered to that board with the wires running out from the bottom. I got a Mausberry circuit to control the power which goes to the switch and led.
                    tikiandskull
                    Nice, I'm trying to make one on the basis of a pi zero with integrated screen, I only have the speakers to install.
                    my project
