    a stop job is running for LSB: ControlBlockService init script
    21 Posts 8 Posters 10.6k Views
      mitu Global Moderator @Derekboy2000
      @derekboy2000 You need to be root in order to be able to delete it. If you say you're able to edit it, just replace the line you referenced with
      exit 0
      and the script should exit without trying anything else.
