    No Retroarch emulators will load
    3 Posts 2 Posters 803 Views
      SuperDannyG
      Ok, I'm going to sound like an idiot, but none of the Retroarch emulators load for me. If I change to a different emulator (the ones that don't start with lr) then it loads fine.
      Also, if I go to the Retropie menu and select Retroarch, then it attempts to load (screen goes black for a second) and then takes me straight back to the Retropie menu.
      I've updated from the latest binaries.
      What am I doing wrong?
        BuZz administrators
        Choose something specific that doesn't work and provide some details - check /tmp/runcommand.log as mentioned when launching.
          SuperDannyG
          Thanks for the response. Luckily I managed to work it out.
          For some reason none of the Retroarch emulators downloaded (not sure why).
          My pi came with Noobs pre installed so not sure if there was a conflict somewhere.
          I flashed it just with Retropie in the end and everything works as intended.
          One issue I did have was my ps3 controller didn't work in game (it worked fine it emulationstation). It turned out that my wireless keyboard was being picked up as the control method in game and not the controller. Once I unplugged the receiver then the ps3 pad worked.
          So all in all everything is now working fine.
          I've got to say, this is an awesome piece of kit! :)
          Cheers.
