    Scraper Issues
    sselphsselph scraperessystemes-screenes-menu
    21 Posts 4 Posters 8.8k Views
      mike27277
      I had gone through and deleted all the games from the gamelists of each system and the images. Made sure ES was closed and ran Sselphs scraper and it still looks the same. I wanted it to have the times played and last time played. Anyone who can help me would be great.
      This is how mines looks
      20170101_093626
      And this is how others looks and the way I want it to be
      theming_list
      One other issue Emulation Station has alot fewer options now it only says sound settings or quit. Under quit it only gives me options to restart not to close ES. I dont know how that happened either.
      Thanks.
      columboscoatC mediamogulM 2 Replies Last reply Reply Quote 0
      • columboscoatC
        columboscoat Banned @mike27277
        @mike27277 change your ES theme. RetroPie uses 'Carbon" as a default theme. Many others are available.
          mediamogul Global Moderator @mike27277
          @mike27277 said in Scraper Issues:
          In addition to @columboscoat's advice on changing your theme, you'll find the theme from your screenshot is known as the 'Simple' theme.
          ... theme.
          herb_fargusH 1 Reply Last reply Reply Quote 1
          • herb_fargusH
            herb_fargus administrators @mediamogul
            @mediamogul prepare for wsod. Anticipate a post on that next :p
              mediamogul Global Moderator @herb_fargus
              @herb_fargus
              Ah, is 'Simple' a white screen offender? To be honest, this is why I just stay with the default 'Carbon' theme.
              • herb_fargusH
                @mediamogul tis why carbon was created and changed to the default for retropie. Though we all know pixel is the best theme
                  mike27277
                  I cant change themes there is no option that is my other issue im having the only option i have is sound settings and quit. I see people on carbon have the more detailed info about times played and last played. I havent been able to get it setup like that.
                    mike27277
                    I made the mistake of using es built in scraper and havent been able to change things since. Deleted all the games from the xml lists and ran sselph but still the same look from my pic i posted.
                      Your screenshot looks normal to me. It could be that you're comparing it to online images of the previous version of Carbon. As for the difference in the ES options menu, can you post an image?
                        mike27277
                        Id like to reset es to fresh settings if possible.
                          mike27277
                            mike27277 @mediamogul
                            @mediamogul i posted an image of my options
                              @mike27277
                              Unfortunately I'm going to have to tag out on this one. I've personally never seen this behavior in ES.
                                mike27277
                                Cam i just reinstall es?
                                columboscoatC 1 Reply Last reply Reply Quote 0
                                • columboscoatC
                                  @mike27277 yip. Reinstall ES from binary.
                                    mike27277
                                    Well i tried zoid theme and i like it has the more info i was looking for. I updated es from binary and all the options are back.
                                    Next to tackle how to make n64 run smother.
                                    • columboscoatC
                                      @mike27277 good luck with that... No insult but better men than you have tried and failed. Miserably. It simply does not work on the Pi.
                                      • columboscoatC
                                        columboscoat Banned
                                        If your post is now solved please mark as solved for those coming behind you.
                                          mike27277 @columboscoat
                                          @columboscoat trying to mark as solved cant find the button
                                          • columboscoatC
                                            @mike27277 NP. It's not the most intuitive forum I have ever used. Anyway, have fun!
