    can't load roms need help
    roms wont work
    5 Posts 3 Posters 1.6k Views
    • L
      legendofthestorm
      Im using a pi zero v1.3 with retropie v4.1 with a pny 32 GB thumb drive trying to load roms onto the pi but when I try to restart the system i get sent to this. 0_1483324461144_01_01_2017_18_12_21.jpg
      i don't know what to do.
        BuZz administrators @legendofthestorm
        @legendofthestorm bad image (incomplete etc) / badly written image or faulty sdcard.
        • columboscoatC
          columboscoat Banned
          Corrupted data on SD card. Format and restart.
          • L
            legendofthestorm
            thanks worded like a charm!
            columboscoatC 1 Reply Last reply Reply Quote 1
            • columboscoatC
              columboscoat Banned @legendofthestorm
              @legendofthestorm yeah, fs errors are rarely good. Not sure how your corruption happened but never pull the plug on a working Pi. Glad you got it sorted.
