    spi screen and zero combo Brainstorming!!!
    zerotftpcb
    24 Posts 3 Posters 10.1k Views
    • mooseprM
      moosepr
      Hi Guys, I have been playing with ili9341 screens and pi's and i came upon the idea that i could improve on the cheep screens that you get on ebay with massive overhanging pcb's
      After doing a bit of planning with a GBA and squeezing a pi inside, i came upon the realization that a 2.8 inch screen and a pi zero are a good size match.
      idea
      so i though 'wouldnt it be a god idea to have a board that combines to 2 as compact as possible'
      so i have come up with this
      https://oshpark.com/shared_projects/1SOL6O7u
      Please do not order this, there are many many problems with it. Just seeing if anyone would be interested in this?
      You would have a pcb, with a 2.8" tft soldered to the front, a Pi Zero soldered to the back, and 20 gpio pins broken out along the bottom edge.
      Any thoughts?
      want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
        I like it. A lot. But then again, I'm a huge fan of those tiny TFTs.
        mooseprM 1 Reply Last reply Reply Quote 0
        • mooseprM
          moosepr @obsidianspider
          @obsidianspider do you think it needs any mounting points? the idea was to have the pcb the same size as the screen so there is no overhang, but some little ears/tabs on the corners might help with attachments?
            thedudester80
            I think if it works how you want it to it would open a door to more possibilities than just a GBA. I'm very interested in seeing how this develops. Great work so far. =]
            Mint Boy, Case Arcade, New Projects Coming soon....
              obsidianspider @moosepr
              @moosepr Mounting for the board itself? I can see maybe having some tabs that could be easily snapped off, but for what I'd want to do with it, I don't know that I'd want tabs. That said, you can always break tabs off if they're there, but you can't exactly put them back on if they never existed.
              • mooseprM
                moosepr
                @thedudester80 yeah i was thinking that it would make any handheld easier (assuming a 2.8" screen fits of course)
                @obsidianspider i was thinking exactly that!! was going to add too many, then it will be more useful to more people, or just lop them off if you dont want them
                I will have a play :)
                  @moosepr Maybe make a few variants of the board with different "ear" configurations?
                  • mooseprM
                    @obsidianspider i was thinking something like this
                    https://oshpark.com/projects/80gXsKOE
                    i need to find out how to add bits properly
                      @moosepr Perfect. That way you can snap off any mounting points you don't need, and they'll be on all four sides as options. Do those have holes for M2.5 (RPi standard) bolts? M3 would also be OK.
                      mooseprM 2 Replies Last reply Reply Quote 0
                      • mooseprM
                        @obsidianspider they have no holes at all yet :P but i think M2.5 is probably a good stab, it keeps everything standard with the zero.
                        the only problem i have spotted, ordering the minimum of 3 boards from OSHpark has now jumped from $28 to $38!!! all that wasted space costs ALOT!!
                        • mooseprM
                          @obsidianspider now $40 once i make the tabs big enough for holes!!!
                          https://oshpark.com/projects/eV0wV0Kg
                            @moosepr Yikes. Maybe some hot glue and tape are a better option ;)
                            • mooseprM
                              @obsidianspider yeah, although ordering larger quantities will lower the price. Drops it from $13.33 per board to about $8 per board.
                              You can find raw screens for about $4 (http://www.ebay.co.uk/itm/371348179488) so that makes it about $12 for the whole thing. Makes it about twice the price of an ebay special with PCB (http://www.ebay.co.uk/itm/271969120935) but more use.
                              Maybe i could kickstarter it and get a few thousand made to lower the cost!!
                              • mooseprM
                                moosepr
                                Righty, i think we are about there with the board.
                                https://oshpark.com/projects/tSdupLd4
                                Just a spot over $40 for a 3 board trial, so i will keep checking, and i am waiting for some trial boards that should be landing by the weekend, these will let me test soldering the pi direct to the pcb onto SMD pads, and be a final test that you can just wire the screen straight to the pi
                                • mooseprM
                                  moosepr
                                  Since when did OSHpark swap the free stickers for free jelly beans? I need to order more often!
                                  Just need the wait for a few more bits, then I will have news....... If it works.......
                                    I got my jellybeans with the $3 I spent when I ordered those power breakouts linked on sudomod. You must have gotten premium jelly beans for $40. ;)
                                    • mooseprM
                                      @obsidianspider this is a smaller test project, only $28. It's scary how that price soon shoots up!
                                      • mooseprM
                                        moosepr
                                        i think i have finalised the board now (i think) just need to find somewhere that can do the boards for less than $40
                                        the other links probably dont work anymore, but this one will
                                        https://oshpark.com/shared_projects/JMQdar5z
                                        • mooseprM
                                          moosepr
                                          China is a good source of boards once you find reasonable shipping (cost/time)
                                          And when they arrive it's always good
                                          boards
                                          • mooseprM
                                            moosepr
                                            its alive!!!
                                            pico :o
                                            some more shots here
                                            http://imgur.com/a/stP5O
