    Cloning SD card need HELP PLEASE
    retropie-setupretropie emu
    6 Posts 5 Posters 3.1k Views
      Corykrist1
      I want to clone my SD card and use it on another system I built so all I have to do is in sort the card and start playing again.... IS THIS POSSIBLE PLEASE HELP ME on my retropie project
      P 1 Reply Last reply Reply Quote -1
        PetroRie @Corykrist1
        @Corykrist1 Yes it is possible. Just check this out:
        https://computers.tutsplus.com/articles/how-to-clone-your-raspberry-pi-sd-cards-with-windows--mac-59294
        You can probably find video tutorials on YouTube too.
          dragonuk
          You can download Win32diskimager, read option to backup sdcard and write option to write to new SD card. This will copy everything include the boot partition.
          https://sourceforge.net/projects/win32diskimager/
          • H
            h00sRdady
            Just make sure you are using the same make/size card as the one you made the image from. I found a Samsung card is slightly bigger than a Sandisk card of the same size and it wouldn't write to the new card.
              Corykrist1 @dragonuk
              @dragonuk now do I have to use the same SD card as the original brand, size and make or can I use a smaller card size lets say I have made a backup of a 32gb card but it's only using 13gb could I clone it to a 16gb card
              Thanks in advance
              synackS 1 Reply Last reply Reply Quote 0
              • synackS
                synack @Corykrist1
                @Corykrist1 Resizing the image created from win32diskimager is a little tricky, but it can be done if necessary. See this post: https://retropie.org.uk/forum/topic/6470/script-to-resize-shrink-win32-disk-imager-retropie-images
                You'll probably have an easier time if you just back up your roms/configs folders after accessing your pi on the network (via \\retropie), and then copy them back onto your new installation on a smaller SD card.
