    MAMEs 0.164 Help Please
    retropie 4.1mame emulationsemulationstatio
    6 Posts 4 Posters 1.7k Views
      GGA
      I recently put together a Pi 3 B and am running RetroPie 4.1 with Emulation Station. I want to add MAMEs for 0.164 but don't see that emulator listed on the Managing ROMs page. Any help would be welcomed. Thank you.
      • rbakerR
        rbaker @GGA
        @GGA You need to:
        a) get a set that matches the supported versions on the Managing Roms Page.
        or
        b) rebuild a working set from your current set.
          PetroRie
          Which emulator are you using? You simply cannot copy and paste a MAME rom into the rom directory and play it. With MAME its kinda different compared to the rest.
          It's what @rbaker said. You can get the romset for fba 0.2.97.39, just use Google. Should take a couple seconds to find the website with the complete set. Once you do just use the lr-fbalpha emulator to play them.
          If you find a different romset you need to "upgrade" or "downgrade" the romset with clrmamepro. It's very easy to do so, the only part that takes so much time is copying them to your Pi :P
            GGA
            I tried using Arcade and he various MAME emulators. None of them worked and that's why I asked. I will have to try the "upgrade"/"downgrade" option I guess.
            columboscoatC rbakerR 2 Replies Last reply Reply Quote 0
            • columboscoatC
              columboscoat Banned @GGA
              @GGA If you want an easy solution get a 0.78 romset. Put it it the arcade folder and use lr-mame 2003 as the emulator. In fact 0.78 is a non-merged set so you could download individual ROMs as zip files and have them work. Unfortunately I cannot tell you where to download the ROMs but if you search for "0.78 reference ROM set non-merged" you should find them.
              • rbakerR
                rbaker @GGA
                @GGA said in MAMEs 0.164 Help Please:
                But 0.164 is not supported, why would they work?
