    Overlay Problems
    overlays
    2 Posts 1 Posters 728 Views
      krull
      Hello,
      After installing the Floob Video Manager (great tool), the N64 and Mame sections still do not have the overlays showing. Any suggestions? I switched (per games) the emulator to a libretro, but don't know how to switch system wide.
      Also, i have saved a bunch of different overlays to my PC. How does one transfer theses files to pi?
      Pi Model or other hardware: 3b
      Power Supply used: CanaKit 2.5A USB Power Supply
      RetroPie Version Used v4.1
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc..)
      USB Devices connected: controller only
      Controller used: Logitech 310
      Guide used: Followed Floobs Guide
      Emulator: Final Burn Alpha and Mame 2003
        krull
        An update........
        I've made sure that the default N64 emulator is libretro. Also, in the Retroarch menu.... the mame overlays/ bezels are clearly downloaded and in the system.
        Any advice?
        Thx
