    ControlBlock Power Switch Issue
    controlblockpowerswitch
    26 Posts 7 Posters 7.3k Views
      dantropie @BakedGoods
      @BakedGoods awesome thanks!!! I'm still new to this stuff. Is there a way to make an edit without uninstalling and reinstalling things?
        petrockblog Global Moderator @petrockblog
        @petrockblog said in ControlBlock Power Switch Issue:
        The location of the configuration file has also changed with the recent driver update. It is now located at /usr/local/etc/controlblockservice.cfg.
        That change has been reverted. The config file is located at its original location at /etc/controlblockservice.cfg.
          dantropie
          Is there a way to edit the powerswitch.cpp without uninstalling and reinstalling anything?
            dantropie @dantropie
            @dantropie is there a way to edit the cpp file from the command prompt?
              @dantropie so I did sudo nano on the PowerSwitch.cpp file and edited the line to shut down now. But it still takes 3-4 min to shut down. Any help?
                You can download and install the latest revision of the PowerBlock driver. You can control the shutdown action now with a shutdown script, see https://github.com/petrockblog/PowerBlock#shutdown-script.
