    2 Player Cabinet - Planning stages
    buttonspowerblockusb controlersvga
    34 Posts 10 Posters 14.1k Views
    • V
      valve90210
      Hi All
      I'm new to the forum and about to embark on a new project to build myself a 2 player bartop cabinet.
      I thought I’d try to put my thoughts together into a thread to try to get things more organised and clear in my mind; to pick the brains of people with more experience and to get some thoughts and advice on how best to go about my project.
      At present I’m at the planning stages and am trying to figure out exactly what it is I want from the project and what I’m hoping to achieve, to put together some criteria and hopefully get some guidance on whether what I’m hoping is possible or not. (I’ll try to make this as logical and simple as possible but to be honest there’s a lot going around in my head and this is in part in an exercise to head clear the mess so bear with me)
      • Arcade classics (pacman, space invaders etc)
      • Arcade games (metal slug etc)
      • Consoles (up to SNES/MegaDrive era)
      • Amiga? (primarily for SWOS)
      • How do game save states work? (Thinking for console type games eg LTTP )
      • Cabinet – Pre-cut kit
      • Monitor - Exisiting
      • Power control – PowerBlock add-on board
      • 2 Player – How many buttons per player (thinking 6 plus coin insert & player?)
      • USB sockets to allow use of joypads instead of Arcade controls? (Is this possible – boot order of USB sockets?)
      That's the rough, all over the place, thoughts I've got spinning round my head at the moment, along with a few questions I've got.
      While I'm thinking about these, I'm also going to be working on getting a Pi3 working with retropie and a spare VGA monitor I have. Does anyone have any experience of this?
      Any thoughts or comments or advice would be very much welcomed.
        If you are building a cabinet, here are some tips:
        Plan out and budget your project - Just so you know what you need.
        Instead of a prebuilt kit, create your own. Or, better yet, find something to use as an enclosure. Like I did here.
        As for controls: check here: https://www.focusattack.com/
        • V
          valve90210 @lilbud
          @lilbud Thanks for the reply. I know I could save myself a lot of money and cusomise things if I built my own cabinet but I've decided on the precut kit cabinet simply for reasons of time. I don't have a huge amount of free time as I have a 5 year son, and that which I do have has so many demands upon it (such as DIY that needs doing round the house) so I figured getting a precut kit would be a huge time saver for me and worth the extra cost.
          I like your build, it's a very nice.
          Any recommendations for UK suppliers for controls etc? I see there are loads of places on ebay that all seem similar so anything to take some of the guesswork as to who is good would be nice.
            Might want to try this site: https://www.ultimarc.com/store/. I used them for my first arcade stick. Since I am in the U.S, it took the upper part of 2 weeks. But should not take too long. I'd recommend using the Minipac, since it lessens the wiring
            • rbakerR
              rbaker @valve90210
              @valve90210 said in 2 Player Cabinet - Planning stages:
              https://www.arcadeworlduk.com/ - Got my parts from here
              http://rockstarprint.co.uk/bartop.html - Graphics
              http://arcadecontrols.com/arcade.htm - Info here
              http://www.instructables.com/id/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/ - Template here
              • H
                hatfield44
                You could definitely do usb for joypads, but if your not wanting to use authentic style controls (NES, SNES, SMS, etc....) and are using a pi 3 you could always use bluetooth joypads (ps3 etc...) to keep a cleaner look for your cabinet.
                As far as the display you should only need a HDMI to VGA adapter.
                  Gee
                  @valve90210 Hi, Take a look on my bartop project here. https://retropie.org.uk/forum/topic/5267/another-bartop-project You will find a list with all the parts I used for the project. Most of the parts was ordered from ebay.
                  • V
                    valve90210
                    Well, my pi 3 arrived yesterday and I spent a bit of time tinkering and getting a bit of a feel for how retropie works. Got some games running and working with my wired 360 controller (I have two of these which are what I intend to use via USB sockets in the cabinet at times).
                    Connecting to my wifi was a little tricky but eventually i got it connected and working.
                    If I get a chance this evening I'll see if I can get it working with my VGA monitor as last night I was testing via HDMI on my tv.
                    Am I definitely right in thinking that I can have my system setup to use arcade controls normally and USB controllers if they are plugged in? If it makes any difference I'm planning on using zero delay USB encoders for the arcade controls
                      As long as you leave a way to plug controllers in without having to take the whole machine apart. Might want to look into a couple of these
                      https://www.amazon.com/StarTech-com-Panel-Mount-USB-Cable/dp/B002M8RVKA/ref=pd_sim_147_4?_encoding=UTF8&pd_rd_i=B002M8RVKA&pd_rd_r=C1MFNM60MF36NXCRRH4C&pd_rd_w=kOMLp&pd_rd_wg=0XiOZ&psc=1&refRID=C1MFNM60MF36NXCRRH4C
                        backstander @valve90210
                        @valve90210
                        Check out this thread:
                        https://retropie.org.uk/forum/topic/5220/arcade-buttons-how-many-layout
                        It might also be nice to have a wired or wireless keyboard handy for maintenance & troubleshooting.
                        Or if it will be on your network, you can also SSH into it from another computer.
                        • V
                          valve90210 @lilbud
                          @lilbud said in 2 Player Cabinet - Planning stages:
                          Cool, good to hear. I've seen some flush fit usb extensions which I was thinking I might use, something like this:
                          https://www.aliexpress.com/store/product/2m-Car-Truck-Dashboard-Flush-Mount-Dual-USB-Male-to-Female-Extension-Cable/1934037_32484318023.html
                          @backstander said in 2 Player Cabinet - Planning stages:
                          @valve90210
                          Oh now tha'ts left me even more unsure how many buttons to have...lol. Thanks that's a useful discussion actually and will give me some food for thought.
                          I have a nice small usb keyboard I can use for troubleshooting etc, and am assuming I could plug it into one of the usb sockets I want for controllers.
                          • V
                            valve90210
                            Another little bit of testing done last night, tried out my HDMI to VGA adapter. Video was fine but I wasn't getting any audio from it. Having done some reading up if I get time this evening I'll try adding to my config to ensure the HDMI is outputting audio as well as video when using the adapter.
                            As an aside, I tested the 3.5mm jack output for audio as I'd heard they weren't good, I have to say I was not quite prepared for just how bad, really noisy and tinny!
                            • V
                              valve90210
                              Last night I got the audio working on my VGA adapter, simply a case of uncommenting hdmi_drive=2 in my config file.
                              Next stage will be buying joysticks and buttons to get to grips with those before then moving onto getting the cabinet...sadly this will have to wait until after payday!
                              • V
                                valve90210
                                While I'm waiting for pay day to finally arrive so I can get on and buy my arcade controls etc I wonder if anyone can help me with a couple of queries I have regarding powering the cabinet?
                                1. I'd like to only need to have one plug to plug in for the cabinet and as such I'm planning on connecting a 4-way socket extension like this:
                                https://www.amazon.co.uk/Eurosonic-2m-4-Gang-Extension-Lead/dp/B000MJYIIO/ref=pd_lpo_23_lp_t_4?_encoding=UTF8&psc=1&refRID=E47NZX4JG6ECJZ46A2QY
                                To one of these switched 'kettle' sockets:
                                http://uk.rs-online.com/web/p/iec-connectors/0815818/
                                Then I can leave the the pi, monitor and speakers plugged into the multi socket inside the cabinet. Are there any problems with doing this?
                                1. I'm wondering what to do about my monitor, when power is removed (ie it's unplugged) it it goes onto standby when power is restored (plugged back in) and needs the button on the front to be pressed to switch it on, however, once the monitor is mounted and the surround is in place I won't be able to get to the button? what aremy options/ is the best way overcome this issue?
                                • rbakerR
                                  rbaker @valve90210
                                  @valve90210 If you look at mine in this picture, you will see that I used a similar power bar to you. It is important to look at which way up it goes as quite a few power adaptors are fatter at one end unlike a plug. This means that you may end up having power adaptors that when plugged in are opposite to each other - this increases the size of the space needed. I also used this connector like yours. I wired it up and it worked no problem so a good choice there. With regard to the monitor, I found one that comes out of standby when the power comes on so no need to press a button. However, I built in access to the front of the cabinet so I could use the speakers and access the controls if needed. I laser cut some blue acrylic to cover the controls when they were not in use.
                                  • V
                                    valve90210
                                    Thanks, good to know my thinking is ok! That's a very good point re the direction of the powersupplies, the one I have for the pi 3 is a non standard shape and can't go opposite another plug (ie top edge to top edge) as it over hangs, I shall certainly bear this in mind!
                                    Last night I had a good look at the monitor I was planning to use for my cabinet to measure up etc and discovered that the stand which I thought was removeable to leave me with VESA mouting holes actually isn't removeable and there are no VESA holes, so seems like a monitor is another item for the shopping list...
                                    Can anyone recommend a 19inch 4:3 monitor with removeable stand, VESA mounting holes and ideally one that switches on when power is restored to it? (in the UK please)
                                    • V
                                      valve90210
                                      Been trawling ebay trying to snag a bargain 19inch monitor, narrowly missed one over the weekend but I'll get there I'm sure.
                                      In the mean time I'm turning my attention to the input side of things. My current plan is to buy a PowerBlock to simplify the on/off of the machine, and use USB encoders for the arcade buttons.
                                      I've done a lot of looking about and found loads of different sellers offering all sorts of options but I'm not 100% sure on what I'm looking for in a USB encoder. They pretty much all claim to be zero delay which I believe is what I'm looking for but I've seen sets where two joysticks and sets of buttons hook up to one encoder board, and others with two encoder boards, one for each player. Which would be best to get? Also, how many buttons do these boards tend to support per player?
                                      • V
                                        valve90210
                                        It's been a while since I made any progress on my project due to gettign sidetracked with other things (mainly RC cars...:)). However last weekend I did move on a little.
                                        I have now gotten hold of a 19inch 4:3 monitor which has a toggle power switch so it will power on when the cabinet is powered up! :)
                                        Also, my brother has been clearing his loft as he's moving in a few weeks, in doing so he stumbled across an old pair of mains powered active computer speakers that he was just going to dump. Instead I have now stripped them down and tested them, they will work very nicely when I put my cabinet together!! :)
                                        I've hooked up the pi 3 I have with my HDMI to VGA&3.5mm stereo adapter. All working very nicely.
                                        My next step is to buy my buttons etc but I still don't know exactly what I'm looking for in terms of the USB encoders, does anyone have any advice on these?
                                        U J caver01C 3 Replies Last reply Reply Quote 1
                                          jamesbeat
                                          I'm going to recommend that you don't put anything except MAME on it.
                                          Hear me out...
                                          Do you want to stand up to play console games?
                                          Arcade games were designed for a short fix, not protracted gaming sessions.
                                          Console games were designed to be played seated comfortably in your sofa on a screen several feet away.
                                          The control schemes are different too, although your idea of usb ports for controllers addresses that problem.
                                          What it doesn't address though is that console games weren't designed to be played on a small screen close to your face, even if you sit at the cabinet to play.
                                          I say build two systems. Put a Pi in a case and hook it up to your TV, and keep your arcade machine purely for arcade games.
                                          I have an arcade cabinet (MAME only), a TV console (consoles only) and I am currently building a desktop machine with a monitor for my computer based emulators (Spectrum C64 etc) as these don't lend themselves well to being played on a distant TV with a controller - they need a monitor and a keyboard.
                                          Just some food for thought from someone who has been in exactly your situation a couple of years ago.
                                          V 1 Reply Last reply Reply Quote 1
                                          • U
                                            UP4IT @valve90210
                                            @valve90210 I used the Xin-Mo control board from eBay with 12 buttons and 2 joysticks as a pack. It works well
