    How to Guide for Cleaning Up ROMs
    lr-mame2003romset
    4 Posts 4 Posters 8.0k Views
      soonerdoc
      Hello all. Fairly new to using emulation software. Setup RetroPie this weekend on a Raspberry Pi 3. Everything seems to be in good working order. Using a 0.78 romset for lr-mame2003.
      Is there a step by step guide out there to help clean up the rom list and get it down from 4000+ to something more manageable? Getting rid of clones and other unecessary roms?
      Thanks so much!
      • rbakerR
        rbaker @soonerdoc
        @soonerdoc You can use a "lite" dat. See here:
        https://github.com/retropie/retropie-setup/wiki/MAME#lr-mame2003
        This will provide a working only, no clones set. It's not an exact match but I have used it with success for what I wanted. Tutorial:
        • FloobF
          Floob
          You can use a tool like this if you want to create a custom list:
          https://www.waste.org/~winkles/ROMLister/
          More details here:
          https://retropie.org.uk/forum/topic/2859/how-to-use-mame-with-retropie-help-guide/
            TKoller
            2 years ago I've created a github-project to cleanup all your roms.
            maybe this is something for you.
            https://github.com/TobiasKoller/RomSetManager
            Best Regards
            Tobias
