    Using a UPS PIco + Fan with RetroPie?
    ups picouninterruptablepower supplyfani2c
    1 Posts 1 Posters 1.0k Views
    • sunwindS
      sunwind
      I just recieved my UPS PIco: http://www.pimodulescart.com/shop/item.aspx?itemid=29
      Also added the fan: http://www.pimodulescart.com/shop/item.aspx?itemid=10
      Everything is built together, http://imgur.com/a/PaBWq
      The installation guide here: https://github.com/modmypi/PiModules/wiki/UPS-PIco-Installation
      Says "Enable the I2C Interface
      Start by opening up the raspi-config menu:
      sudo raspi-config
      Then from the options, select "Interfacing Options"
      Then down to "I2C" and select "Yes" to enable it."
      So I do that, but there is no I2C option to be found, so I can't really progress it seems as everything relies on that, anyone tell me what I might be doing wrong here? or does retropie have this option removed from a standard raspbian installation?
      Thanks in advance,
      sunwind
      edit: option has been moved to another menu item
