    PC Engine Game Help
    pc engine cdturbografx16wont load black
    9 Posts 4 Posters 3.2k Views
      Jeremy.Gracias
      I am trying to get (Cosmic Fantasy 2) to work on my Pi unit.
      every time i try to run the game it boots me back to the game selection here are some of the steps i have done so far:
      updated EVERYTHING i could on the retro pi.
      tried the 2 different emulators that are available.
      replacing/renaming syscard3.pce
      I have a (card pack) that i downloaded and added as well. (SUPER/CD-ROM SYSTEM V2/3.pce)
      made sure the bin and the cue names match perfectly.
      i was wondering if anyone was able to get this game to work, and if so, the steps that you used to get it running.
      I have the original game but i cannot seem to rip a new bin from it (tried a few different methods to no avail)
      thank you in advance,
      I would love to play my favorite childhood game again.
        edmaul69 @Jeremy.Gracias
        @Jeremy.Gracias did you put the syscard3.pce (all lowercase including extension) in /home/pi/RetroPie/BIOS/ ?
          Jeremy.Gracias @edmaul69
          @edmaul69
          Yes i have placed it in BIOS and in the ROM set and verified that the ROM works as well.
            @Jeremy.Gracias you said you renamed the syscard3.pce file? If so it might not be the correct rom. I would google the correct name and download the known correct one if that is the case.
            • DarksaviorD
              Darksavior
              It seems like you're just trying anything blindly. Read this first https://github.com/retropie/retropie-setup/wiki/PC-Engine
              If the game works on a pc emulator, it's time to check the cue file. Pi is case sensitive.
                @edmaul69
                I will scour the net and see if i can find another Download for (Cosmic Fantasy 2).
                Ill let you know what i come up with tonight.
                thanks.
                  Jeremy.Gracias @Darksavior
                  @Darksavior
                  these were all suggestions from this and other forums that said that solved the issue. i will look at the link provided tonight and see if anything that i haven't tried is on it.
                  i would love to make a Bin/Cue for the original game. " since i already have it. " but any methods that are out there will not work with my blueray burner for some reason (LG model)
                  thanks for your suggestion i will post back as soon as i am able and hope i can get it to work "fingers crossed"
                    backstander @Jeremy.Gracias
                    @Jeremy.Gracias
                    Back-in-the-day I believe I used CDRWIN v4.0 to rip my TG-CD discs. I tried the newer versions of CDRWIN but only the version 4 actually does the job correctly (even thought I haven't tried it in any OS's newer than Windows 7). I know nothing about Blu-ray burners so they could be causing issues as well.
                    Also make sure that your BIOS file has a md5sum of ff1a674273fe3540ccef576376407d1d
                      Jeremy.Gracias
                      Thanks everyone for your help!.... got it running finally.
                      Turns out it was a (TINY) error in the cue and bin names that i over looked.
                      GAME ON!!!
