    TurboGrafx-16 - Only a few roms running
    turbografx-16pcengine
    23 Posts 5 Posters 16.3k Views
      swaggers
      So I have a Pi 3 running 4.1 and when trying to run TurboGrafx-16 roms it just loads a black screen for 90% of the roms. Out of a dozen I've tried Bonk's Adventure 3 and CyberCore run, but the rest just load into a black screen. Any ideas what I am missing. I've tried both emulators to the same effect.
      • L
        liquidzoo
        Have you tried them on an emulator on your PC (for example) to make sure that they're good ROMs? I know that in some cases there may be a lot of bad copies out there that might not work.
          swaggers
          Tried in MagicEngine on my PC and everything runs no problem.
            swaggers
            Anyone who is successfully running TG16 which emulator are you using?
            I've got the syscard3.pce in BIOS and I'm not running any CDs. A few of the ROMs work but most do nothing. Just a black screen that I can exit out of. All of them appear to work in Magic Engine on my PC.
              backstander @swaggers
              @swaggers
              I have TG16 roms and CDs working. Check to see if your BIOS file has a md5sum of ff1a674273fe3540ccef576376407d1d
              Seams like I had to try a couple BIOS files until I found one that worked.
                swaggers @backstander
                @backstander
                Got the same checksum on my BIOS. It's in /home/pi/RetroPie/BIOS
                I've tried both lr-beetle-pce-fast & lr-beetle-supergrafx
                When a ROM is starting I see the controller getting selected in green in the bottom left hand corner of the screen and then everything goes Black.
                This is what my runcommand.log is saying:
                Parameters:
                Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-beetle-pce-fast/mednafen_pce_fast_libretro.so --config /opt/retropie/configs/pcengine/retroarch.cfg "/home/pi/RetroPie/roms/pcengine/Bonk's Adventure (U).pce" --appendconfig /dev/shm/retroarch.cfg
                unhandled setting F: pce_fast.mouse_sensitivity
                  @swaggers
                  I checked last night and my md5sum is 0754f903b52e3b3342202bdafb13efa5
                  So I updated the wiki with this information:
                  https://github.com/RetroPie/RetroPie-Setup/wiki/PC-Engine
                  I'm not sure what the differences are between the 2 BIOS versions but the one I have has worked very well for me for both TG16 and PC Engine ROMs and CD bin/cues. I can even play all seven games for the PC Engine SuperGrafx using lr-beetle-supergrafx.
                  The error you're getting is "unhandled setting F: pce_fast.mouse_sensitivity".
                  Another thread suggests it's a bad ROM file:
                  https://retropie.org.uk/forum/topic/997/multiple-pcengine-roms-don-t-work/5
                    @backstander
                    There are roms called Sounds. Do I need those? I think I got rid of all of those the first time through the set. I just wanted the "best" US release so I deleted anything that wasn't the main (U).pce
                      @swaggers
                      I'm not sure that I've seen those or know what they are unless those are homebrews. When I'm look for full romsets, I usually get the "No-Intro" sets and not the "Goodsets". A "No-Intro" set usually has all the best know working roms in one collection.
                      • No-Intro: one good ROM for each region or revision of a game (usually one US, one Europe, and one Japan) and no hacks, bad dumps, homebrew, etc
                      • Goodsets: a collect of as many known dumps as possible into one set including the good, the bad, hacks, multiple dumps and homebrews
                      From a "No-Intro" set you could easily do this and just keep all the (U) or (USA) roms.
                        @backstander
                        Thanks for all your help man. Ended up being a bad rom set. Funny thing is found the exact same one on quite a few sites, found a no intro one and they all work fine now.
                        • DarksaviorD
                          Darksavior
                          You don't need the bios to run roms. It's only for cd games. There is a bad syscard3 that will load a few cd games with an error. Sylphia was one of them. I don't know the checksum but the working bios is dated from 2000. The one from 1996 is bad.
                          Update:
                          FF1A674273FE3540CCEF576376407D1D is good
                          0754F903B52E3B3342202BDAFB13EFA5 is bad (but will still work with most popular games)
                          B 1 Reply Last reply Reply Quote 2
                            backstander @Darksavior
                            @Darksavior
                            Hmmm...I wasn't aware of this.
                            Lakka's Wiki for BIOSes states that 0754f903b52e3b3342202bdafb13efa5 is good:
                            https://github.com/libretro/Lakka/wiki/BIOSes
                            • DarksaviorD
                              Darksavior @backstander
                              @backstander Odds are they never encountered a game that loaded to an error. I encountered two so far. Future Boy Conan and Sylphia. They will load to a picture of japanese writing saying something about error reading the system card.
                              B edmaul69E 2 Replies Last reply Reply Quote 1
                                @Darksavior
                                I have updated the wiki to reflect this!
                                I tested those 2 games you mentioned and got the same results.
                                I also noticed that the better version of the syscard3.pce BIOS says "PC Engine" at the "System Card interface" and the other one does not say that. My guess is that the one that doesn't say "PC Engine" is probably the American version.
                                Examples below:
                                DarksaviorD 1 Reply Last reply Reply Quote 1
                                • DarksaviorD
                                  @backstander Nice find. Maybe there's something wrong with the "american" dump since I don't believe there was any region protection on cd games. Only the hucards.
                                    edmaul69 @Darksavior
                                    @Darksavior it is true that there isnt protection on the cd's, however if you need a specific japanes system card then you can have an issue. For example the arcade cd's. Also on a turbografx not a turbo duo, if you need a newer card, like the arcade card pro or the super rare 3.0 card that could be an issue. As far as a turbo duo, the arcade cd's are the only ones i know of that needs the arcade card duo (or pro if you have it)
                                    • DarksaviorD
                                      Darksavior @edmaul69
                                      @edmaul69 I know of the arcade card and these two games that wouldn't load on the american bios aren't arcade cd games.
                                        @Darksavior i have a lot of cd games, i just dont have either of those games. I wonder what their difference is. The us bios is either from the turbo duo or the rare system card 3. I would guess the system card 3. Im not sure the difference in the bios' from the japanese one is. Most of my stuff is 3000 miles away in storage, but i am going back there on the 23rd. So if i remember to pull out my turbo duo while i am there i want to test those two games.
                                          @Darksavior well it looks like the 7 cd games from hacker international required their games express card. Not sure if the games express card works on retropie.
                                            edmaul69
                                            I also forgot, altered beast only works on system card v1.0. However it is working on here with the pc engine syscard3.pce. Strange.
