    Retropie with Adafruit PiTFT 2.2" and model A+
    model a+
    4 Posts 3 Posters 1.5k Views
    • andréA
      andré
      Hey guys! :-)
      I'm doing a portable game grrl-kind of project where I have a Raspberry Pi model A+ and an Adafruit PiTFT 2.2" display. I'm stuck trying to get the Retropie to work with the display, as my Pi doesn't have network access and I haven't got my mobiles tethering to work either... and the only way I've found to install the display drivers is by having network access.
      Does anybody have like a pre-made image with Retropie+2.2" driver preinstalled or could guide me how to do this? :-) I have a console cable if that helps.
      Any help would be much appreciated!!
      senkunS 1 Reply Last reply Reply Quote 0
      • senkunS
        senkun @andré
        @andré
        look in /boot/overlays/
        if I remember correctly, for your 2.2" you should be able to use either;
        pitft28-capacitive
        pitft28-resistive
        • andréA
          andré
          Thanks for the reply @senkun! :) I found a file called "pitft22.dtbo" online and which I added to the overlay folder from my stationary computer. I then added this line to /etc/modprobe.d/adafruit.conf file
          options fbtft_device name=adafruit22a gpios=dc:25 rotate=270 frequency=32000000
          Also I added the following to /boot/config.txt
          [pi1]
          device_tree=bcm2708-rpi-b-plus.dtb
          [pi2]
          device_tree=bcm2709-rpi-2-b.dtb
          [all]
          dtparam=spi=on
          dtparam=i2c1=on
          dtparam=i2c_arm=on
          dtoverlay=pitft22,rotate=270,speed=32000000,fps=20
          This however did not make it work. Do you have any ideas what I can do further? :) Is there any other way I otherwise can install the drivers already when I create the SD-card?
          glennlakeG 1 Reply Last reply Reply Quote 0
          • glennlakeG
            glennlake @andré
            @andré It might be worth it to get a usb wifi dongle or a usb ethernet dongle to connect to the internet to configure your build. That could always come in handy for updates or transferring roms.
