    How can I have both a fan and a power switch?
    power switchfan
    4 Posts 4 Posters 2.2k Views
      TheComicCondor
      I'm new to the site and I plan on making a console out of a broken Retron 1. I would like to use the power and reset buttons already on the console, I would also like to install a fan on the inside for overclocking. I can find instructions online for only having one or the other, but not for both. Can anyone give me a hand with this? Any help would be much appreciated.
        edmaul69 @TheComicCondor
        @TheComicCondor what version of raspberry pi are you using. Cant tell you without knowing that first
        • edm203E
          edm203
          I actually bought a 2.5amp power supply with an on/off button off of ebay. Works beautifully. Unfortunately, not being sold anymore. Didn't get this specific one but it should work:
          http://www.ebay.com/itm/Gowoops-5V-2-5A-Power-Supply-Adapter-Charger-and-Micro-USB-Cable-with-On-Off-and-/182440186247?hash=item2a7a485187:g:xksAAOSwImRYkNwL
          Pi Model or other hardware: Pi3B
          Power Supply used: 2.5 amp power supply
          RetroPie Version Used: 4.2.10
          Built From: Premade from Retropie website
          USB Devices connected: 4x ibuffalo snes controllers
            dannybuoy
            Many ways!
            • A power supply with a switch on so you can power down the unit after you've done your safe shutdown.
            • Power the fan from the USB port so that it goes of with the Pi.
            • One of these circuits that will shut off the power to the whole device a couple of minutes after the shutdown is initiated (although you might need a new case):
            https://www.msldigital.com (they have a riser cable to get it away from your fan too)
            http://mausberry-circuits.myshopify.com/collections/frontpage
            https://lowpowerlab.com/shop/product/91
