    New comic theme and SVG problems
    themesvg
    54 Posts 24 Posters 23.0k Views
    • lipebelloL
      lipebello
      Update on the detailed menu.
      Retrorama Tshirts:
      https://www.teepublic.com/user/lipebello
      https://www.instagram.com/phillbello/
      mattrixkM 1 Reply Last reply Reply Quote 3
      • mattrixkM
        mattrixk @lipebello
        @lipebello I like it a lot. The lines behind the box art look great.
        I think I like the font you used for the Logo on the System View more than this one though.
        lipebelloL 1 Reply Last reply Reply Quote 2
        • lipebelloL
          lipebello @mattrixk
          @mattrixk Thanks, this logo is just a test. i'm thinking in remake the logos to match booth system and menus
          Retrorama Tshirts:
          • RionR
            Rion
            @lipebello Have you implemented video support for this theme?
            FBNeo rom filtering
            Mame2003 Arcade Bezels
            Fba Arcade Bezels
            Fba NeoGeo Bezels
            • screechS
              screech
              I'm comming a little after the war ^^ but 80Ko for a png logo is "huge"...
              Did you try some "compressor" ?
              I recommand you optipng or pngquant... your png logo will be near the same size as svg ;)
              (Your Theme is great ^^ do you think of create a MIX template with UXS ? maybe you can give a comics style to the media you show in the detail vue with some more media (like you did on the system view, some cut between the cover and a screenshot for exemple... If you want I can give it a try ;) )
              CapemanC 1 Reply Last reply Reply Quote 1
                robertybob
                I Love the look of this theme! Are you planning on doing all 80+ systems?
                • CapemanC
                  Capeman @screech
                  @screech actually 80Kb for a PNG logo is extremely small, pngs are raster and come in around 500kb to 1mb if around 1000px wide at 72dpi when set to 24bit with alpha transparency. If you are talking SVG which is vector based, then yes 80kb is a definitely on the heavy side.
                  Also, this theme looks awesome!
                  • screechS
                    screech
                    112kb for a 560x203 png logo with lot's of transparency is pretty huge ;)
                    just to test, I take your first logo and pass it through pngquant.
                    The result : http://s000.tinyupload.com/?file_id=03683192736298317951
                    From 112Kb to 27Kb...
                    I think you can give it a try ;)
                    Your 112Kb :
                    My 27Kb :
                    CapemanC lipebelloL 2 Replies Last reply Reply Quote 2
                    • CapemanC
                      Capeman @screech
                      Well would you look at that, i learned something today. What the tool you posted does is output an 8bit png with full alpha transparency, 8 bit is way smaller than 24bit. Given i work on photoshop every day i had to look into this further, and i was quite surprised that photoshop can't output png8 with alpha, it defaults to using indexed color when saving anything under 24bit and you lose alpha trans. That tool is pretty awesome, really useful for web design!
                      • lipebelloL
                        lipebello @screech
                        @screech - Thanks for the advice. Turns out that i was using the artboard resolution, wich gives me a lot of space with transparency.
                        Now i have around 20KB per logo.
                        I have made new logos to used on system and menus. Trying to made it look like the super heroes logos.
                        0_1486190628840_02.png 0_1486190640488_03.png 0_1486190648494_04.png 0_1486190659471_01.png
                        Retrorama Tshirts:
                        edmaul69E 1 Reply Last reply Reply Quote 3
                          Kischa @lipebello
                          @lipebello I really hope the font "shaka pow" will be in the final release??! :)
                          lipebelloL 1 Reply Last reply Reply Quote 1
                            edmaul69 @lipebello
                            @lipebello I really need this! :)
                            • AliendonA
                              Aliendon
                              Nice work, thats a really cool looking theme
                              • HurricaneFanH
                                HurricaneFan
                                Will this theme have Video previews?
                                • lipebelloL
                                  lipebello @HurricaneFan
                                  @HurricaneFan no, i will adjust the size of the images that comes from scrapper.
                                  Retrorama Tshirts:
                                  • lipebelloL
                                    lipebello @Kischa
                                    @Kischa i'm making new logos to fit all menus.
                                    Retrorama Tshirts:
                                    Z mattrixkM 2 Replies Last reply Reply Quote 4
                                    • Z
                                      zoop @lipebello
                                      @lipebello I second the request of the Shaka pow logos. Hoping there is a version using those instead of the redone superhero style. The superhero also looks nice, just think the Shaka pow makes it looks amazing.
                                      Great work!
                                      • mattrixkM
                                        mattrixk @lipebello
                                        @lipebello I have to say I'm with @Kischa and @zoop on this one. While the "superhero" logos look good, and you've obviously put a lot of work into them, I much prefer the "shaka pow" logos you had in the original images (either with the dithering or without, both look great).
                                        HurricaneFanH 1 Reply Last reply Reply Quote 1
                                        • HurricaneFanH
                                          HurricaneFan @mattrixk
                                          @mattrixk It would be cool to include both in the theme, then users could use the ones they liked the most. I liked the original ones he posted in the first screenshot too. But the 2nd batch looks neat also.
                                          • mattrixkM
                                            mattrixk @HurricaneFan
                                            @HurricaneFan That is true, but it's also twice as much work for @lipebello. With potentially 80+ systems to cover, making a theme takes a lot of time as it is.
