SNES and PS4 controller not working
When I play SNES roms my PS4 (DualShock4) Controller does not work. I have ds4drv installed and my input is configured correctly. But on the menus in the games, my controller doesn't work, but IF I manage to get into the actual game it works fine. Please help me fix this as I've been trying for over 2 hours.
Pi Model or other hardware: 3
Power Supply used: Default Power Supply Shipped with the Pi
RetroPie Version Used (3.6, 3.8.1, 4.01 etc.. - do not write latest): 4.1.2
Built From: Premade RetroPie image
USB Devices connected: None
Controller used: PS4 (DualShock 4)
Error messages received: None
Emulator: All snes9x emulators installed -
@Thrilla does it work fine with other emulators? Also you need to say the exact snes emulator you are using. Is it the libretro one?
@meleu On lr_snes9x all of them
@Thrilla did you figure out the problem. I'm having the same issue but in all the roms. The controllers only work in the main menu (or home screen) of Retropie. I've been looking for weeks but all I see are the monitors/ the ones who might know, keep asking questions and not giving any proper solutions. It's not that hard to answer a question when it seems like many are having the same issue. From what I read online that is. It's funny how they what you to be specific when many can't reply back being specific.
@Schmitstix Maybe you should open a new thread for your issue and post your specs??? Commenting on a 3 month old post asking for an answer when they know nothing about your setup is going to get you nowhere.
@buddyscott It got you to reply plus it doesn't hurt to try. However, thank you and I'll try a new thread.
