    Psp problems?
    psximageforward porttransfering
    12 Posts 6 Posters 5.1k Views
      mountaindew117
      Not asking for any bios images or roms here I'm just asking why doesn't my psx files show up in my list?
      Am I installing them wrong or am I not doing something correctly. I have a game that I used an application that can convert a muti-disc game into a single eboot file that I used on my psp?
      Am I doing that right or am I completely missing something?
      Also is it possible to transfer files from my computer to my pi via ethernet cable, plug into each other kinda like a Lan line? And using Filezilla to transfer all my content this away?
      Beretta9B rbakerR 2 Replies Last reply Reply Quote 0
      • Beretta9B
        Beretta9 @mountaindew117
        @mountaindew117 eboots go in the psx rom folder.
        Retro Gamer Supreme
        • CapemanC
          Capeman
          When some of those programs create an eboot, they sometimes package the files in a zip with cd artwork and other files that the psp needs to play them. If that is the case, you need to go into that zip file, remove the .pbp file and just use that as your game for retropie. Not the whole zip file.
            mountaindew117 @Beretta9
            @Beretta9 I have it in the roms folder but it's still not showing up
              dankcushions Global Moderator @mountaindew117
              @mountaindew117 said in Psp problems?:
              what's the full file path of your file, including extension?
              eg: /home/pi/roms/RetroPie/psx/mygame.pbp
              • rbakerR
                rbaker @mountaindew117
                Please describe what you are doing.
                What are you doing?
                Yes, I use winscp, best place to start is:
                https://retropie.org.uk/forum/topic/3/read-this-first - which I think you have missed somehow. Then onto this:
                https://github.com/retropie/retropie-setup/wiki/ssh
                Then
                D M 2 Replies Last reply Reply Quote 0
                  Dochartaigh @rbaker
                  Also, once you get everything sorted out so they show up in the ROM list, you should also look at the PSP compatibility list as well? Some games just won't work, period (which ironically for me, was every single PSP game I wanted to play ;(
                    mountaindew117 @dankcushions
                    @dankcushions said in Psp problems?:
                    Not sure how to check that in the console mode?
                      mountaindew117 @Dochartaigh
                      @Dochartaigh lol I just noticed that my post said psp problems but it's suppose to be psx problems
                        mountaindew117 @rbaker
                        @rbaker said in Psp problems?:
                        What are you doing?
                        Then
                        I have watched etas video before using the file browser over my WiFi connection but the pi losses connection to my Internet during data transfers.
                        I have been using psx2psp to make eboot files for my psx games and putting them in my roms folder under the psx folder then I reboot the pi but the psx emulator still doesn't show up
                          ls -l /home/pi/RetroPie/psx
                          paste output here
                            Got it to work found out that the file never fully transferred over and thats why it wasn't showing up. Also if you use filezilla to transfer files over a ethernet cable make sure you use port number 22 or it will not let you connect to the pi
