    Use usb - automount and loading splashscreens from sd-card possible?
    automountsplash-videosplashfailedboot
    5 Posts 3 Posters 4.0k Views
    • Capt_MorganCreekC
      Capt_MorganCreek
      Hi,
      I'm having trouble with (video-) splashscreens on the latest retropie 4.1 using the easy automount option.
      Automount usually works very reliable and I don't have any issues loading roms or anything else, but about 1/3 of the time the USB stick initialization fails before showing the splashscreen, so my video does not play.
      Error message is:
      [FAILED] failed to start usbmount@dev-sda.service
      See 'Systemct1 status usbmount@dev-sda.service' for details
      I would guess the usb device does not always initialize fast enough to be used. The stick is a SanDisk Ultra Flair 64GB usb 3.0.
      Can I store the splashscreen on the SD-card to prevent this from happening? I know it's a only small annoyance, but I'm crazy perfectionistic about this stuff.
      Thanks!
      Pi model or other hardware: 3B
      Power supply used: 3a
      RetroPie version used: 4.1
      Built from: Pre made SD Image on RetroPie website 5th November 2016
      USB devices connected: Keyboard, HuiJia GamePad (N64 usb adapter)
      Controller used: N64
      Guide used: Official Installation Guide
      RetroPie64 - My Nintendo 64 conversion: https://retropie.org.uk/forum/post/55927
        BuZz administrators @Capt_MorganCreek
        @Capt_MorganCreek Yes, if using a custom splashscreen and using automount you should place it elsewhere. Just copy it to /home/pi or somewhere and adjust /etc/splashscreen.list to the new location. (you can manually edit this from the splashscreen configuration menu)
        • E
          EctoOne
          I had the same problem and in the end I've put my video into /opt/supplementary/splashscreen/
          It's the same folder the pre installed Splashscreens are in and so far it works fine. It's easy to set up from the configscreen afterwards.
          • Capt_MorganCreekC
            Capt_MorganCreek
            Thanks guys!
            This is exactly what I was looking for :)
            • Capt_MorganCreekC
              Capt_MorganCreek
              Hmm. I followed your advice and copied the video-splashscreen over to /home/pi/splashscreens and changed the line in /etc/splashscreen.list accordingly. Strangely this doesn't work, the splashscreens never appears.
              I even double- and triple-checked the paths and tried different folders, but the splashscreen won't show up.
              Edit:
              Just got it to work. After copying it over to /opt/retropie/supplementary/splashscreen/ to the default splashscreens and selecting it it works like a charm!
