    Fix Up/Left joystick direction for THT 2P arcade controller with device ID 0x75e1
    controllerxin mothtaxis
    21 Posts 5 Posters 10.5k Views
    • rkosterR
      rkoster @godsephiroth
      @godsephiroth If you follow the instructions in my post here: https://retropie.org.uk/forum/topic/7832/fix-up-left-joystick-direction-for-tht-2p-arcade-controller-with-device-id-0x75e1/9 it should work for 05e0. The location in each file to make those edits is most easily found if you just
      sudo nano <filename>
      search for XIN_
      add the line right after the existing entry
      Github/helper scripts * Creativision/Arcadia/Astrocade guide * Amiga guide * Atari 8bit guide
