    Wireless controller battery indicator
    controllersbatteryimprovementssuggestion
    3 Posts 3 Posters 1.7k Views
      joestrong
      Is there currently any way to see the battery status of a wireless controller?
      I'm currently using a PS3 controller over bluetooth, and when the controller battery runs out it will disconnect without prior warning.
      Is there any project working on anything like this?
      B edmaul69E 2 Replies Last reply Reply Quote 0
        backstander @joestrong
        @joestrong
        Doesn't the PS3 controller start flashing a red light a couple of times like every 30 seconds warning you that your batteries are low? My Xbox 360 controller does something like that and I believe the Logitech ones do this as well.
          edmaul69 @joestrong
          @joestrong as the man above me stated. And when it blinks it shows 1-4 lights at once. The less lights you see the less battery power you have. You can see this when you turn on your controller on as well
