    Set a static IP address for cable connection
    ethernetip address
    3 Posts 2 Posters 5.5k Views
      gas1979
      Hello, can you please help me? I need to connect my raspberry pi 3 with retropie to my LAN.
      All the guides I've found talk about how to set WiFi IP address, but I must change the ethernet cable IP connection...
      Thanks in advance!
      Gas
        BuZz administrators @gas1979
        @gas1979 https://www.jeffgeerling.com/blog/2016/setting-static-ip-address-raspbian-jessie-lite-on-raspberry-pi
          gas1979
          It works perfectly, thanks a lot!
