    Hdmi to vga adapter not working
    hdmi vga problevga
    23 Posts 4 Posters 10.9k Views
      joelw23
      https://www.amazon.com/gp/product/B00ZMV7RL2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
      this adapter is not working with my raspberry pi 3..i get no signal on a 17" dell monitor that is known to be good.
      I have uncommented these lines in the config.txt file.
      hdmi_safe=1
      hdmi_group=2
      hdmi_mode=16
      hdmi_drive=2
      config_hdmi_boost=7
        edmaul69 @joelw23
        @joelw23 you need to get rid of hdmi safe. Not sure why you have safe mode on. Plus why is your hdmi boost on 7?
          joelw23
          because i was trying everything to get it to work...
          i'll turn safe mode off and put the boost back to 4 and try.
            joelw23
            same result....
            monitor stays in sleep mode w/ yellow light on power button.
              edmaul69 @joelw23
              @joelw23 if you do it should work fine. Its the same settings i use. I have a 15" tv though. Are you sure you cant set yours to 1280x something? (not sure if you have a widescreen or not) I would try getting it working on mode 16, 1024x768 first (if you dont have a widescreen) It is the setting you have it on right now.
                joelw23
                right...
                everything i've read has said it "should" work, but all of the setting i've tried have produced no picture....
                maybe the adapter is bad.....
                  edmaul69 @joelw23
                  @joelw23 can you tell me the model number of your monitor?
                    joelw23
                    E173fp
                      edmaul69 @joelw23
                      @joelw23 the webite with the resolution settings isnt working so i cant tell you what the hdmi mode is for 1280x1024 since i am not home at the moment but add this setting too.
                      hdmi_force_hotplug=1
                        joelw23
                        Thanks but that setting is on as well
                          edmaul69 @joelw23
                          @joelw23 change your hdmi mode from 16 to 35. You can try 37 as well but i believe 35 is correct for your monitor
                            joelw23
                            tried 35...still nothing..
                            config.txt here:
                            http://pastebin.com/RVvH0uDY
                              joelw23
                              also just tried another vga cable just to be sure.. same result
                              when i unplug the vga cable the monitor goes in to "self test feature check" mode
                              when the vga cable is plugged in, it goes right in to sleep mode with the yellow light on the power button.
                                BuZz administrators @joelw23
                                @joelw23 if posting configs, please put them in a code block for readability http://commonmark.org/help/
                                  joelw23
                                  I have also tried a usb cable that plugs in to the wall in case the pi3 wasn't giving enough power...
                                  monitor is still in power save mode with no signal.
                                    joelw23
                                    the company that sold the adapter is sending me a new one to try...
                                    hopefully this one is defective.
                                      edmaul69 @joelw23
                                      @joelw23 this could be a possible issue or it was from how you copy and pasted, but why do all the words "uncomment" not have hashtag "#" in front of them?
                                        joelw23
                                        must be how it copied an pasted...they do have a # in front of them in the config.txt file
                                        • flopF
                                          flop
                                          Hmmm, I got this model :
                                          https://www.amazon.es/cambiador-ordenador-portátil-Proyector-Raspberry/dp/B00F6RZZMU/ref=sr_1_6?ie=UTF8&qid=1486660818&sr=8-6&keywords=hdmi+to+vga
                                          And It worked for me, but needed to set "hdmi_drive=2" (uncomment the line in /boot/config.txt) for get a good quality image; if not, the colours looks strange.
                                          Note: Uncomment means that you should delete that # to get that code line working (no spaces too)
                                            edmaul69 @flop
                                            @flop ditto. i use this same one. i also have another type that works too but i like this one much better because of quality
