    NES30 Pro and RetroArch/PSCX
    8bitdoplaystation 1nes30 propcsx-rearmedpcsx rearmed
    3 Posts 2 Posters 1.2k Views
      jateed
      Hello everyone,
      My RetroPie is coming along, and for the most part, everything works, but I am running into a problem with PCSX-Rearmed and my controller.
      First, I tried loading the Libretro version of PCSX-ReArmed, but it keeps taking be to the Bios screen with the memory card/CD Player, and I can't actually load the game.
      So, I tried using regular PCSX-ReArmed, and while the game loads fine, I cannot get my 8Bitdo NES30 Pro to configure properly. I got into the PCSX controls menu, but it won't map the D-Pad at all (which renders a lot of PS1 games inoperable).
      So, now I am stuck. Ideally, I would love to get the Retroarch version to run properly. I read that there is a "Skip Bios" option, but I cannot find it anywhere.
      However, if that is not an option, I'd be content with being able to configure my controller properly inside the emulator itself, but again the D-Pad.
      To Assist, here are my specs:
      Raspberry Pi 3
      64gb Samsung EVO Micro SD
      2.5a Power Supply (no lightning bolt at all)
      8Bitdo NES30 Pro
      RetroPie 4.1.14 (setup script is up to date)
      All optional packages installed
      The controller works on every other system I have tried it on, except for Dreamcast, but that's a story for another date.
      Any help anyone could provide would be great! Thank you!
        BuZz administrators @jateed
        @jateed If you update lr-pcsx-rearmed from binary it should be fixed.
          jateed @BuZz
          @BuZz Thank you Buzz. I actually just figured it out by gaining access to Retroarch's quick menu using the in-game hotkey, then fiddling around in there till I found something mentioning Bios.
          But anyway, everything works now, except for reicast. But thank you all the same.
