    NES30 PRO/ FC30 PRO
    nes30 proretropie 4.1button
    12 Posts 10 Posters 3.3k Views
      Sébastien
      Hello guys
      I'm new in here and a have a little problem.
      I build a Retropie (Pi3) and i bought some beautiful NES30 Pro Controller (and a 2nd FC30 PRo :D but it's for another question)
      I've installed the controller ... in Retropi it works fine but when i 'm launching games it doesn't work anymore exept for the D-pad ... all the buttons aren't working ...
      Can some one help me
      Thank you
      PS : i am a a beginner with Rpi so be kind :D
      Pi Model: 3 Model B
      RetroPie Version Used: 4.1
      Built From: SD Image
      USB Devices connected: Keyboard dongle
      Controller used: NES30 PRO / FC30 PRO (firm 1.71)
      Error messages received: No message seen
      Rpi3 + NES30Pro / FC30Pro + Retropie 4.1
      BuZzB J 2 Replies Last reply Reply Quote 0
        BuZz administrators @Sébastien
        @Sébastien did you follow https://retropie.org.uk/docs/8Bitdo-Controller/ ? Note firmware and hack mode setting.
        Please note the link at the top of the screen when posting for help. (Which you agree to read when registering).
          Sébastien
          yes i've followed these instructions
          i've tried with and without the Hack
          BuZzB R 2 Replies Last reply Reply Quote 0
            @Sébastien did you reconfigure the controller in emulationstation after switching the hack mode? If you update firmware hack should be off.
              ray2272 @Sébastien
              @Sébastien
              I use these same gamepads for my RetroPie, and I will admit it was frustrating to get them up and running. Like you, I set it up under the inputs section of the menu that pops up when you press start, and, as a result, had to deal with the gamepad working perfectly in EmulationStation, and then doing nothing once I started a game.
              Assuming that the games you're playing are not through computer emulators like DosBox (which requires its own configuration), and instead, are for old consoles leveraging emulators that work well with RetroArch, I needed to actually go into the RetroArch configuration in the RetroPie menu. Once there, under Inputs, I set both the player 1 binds and hotkey binds there. After saving the configuration settings on exit, I started a game and the controller worked perfectly.
              Hope that helps you.
              • RionR
                Rion
                1. Reset the controller configuration by exiting EmulationStation pressing F4. Type
                sudo /home/pi/RetroPie-Setup/retropie_setup.sh
                Reset EmulationStation controll configuration.
                1. Unpair your 8bitdo controller in the BT setup.
                2. Connect your 8bitdo gamepad to your PC (fully charged) and upgrade to the latest Fw from 8bitdo's website.
                3. Redo the controller configuration in BT Setup.
                  Make sure the hack option is turned "off" and that you power on the controller with start only!. On the pro only start up with power on.
                After you are done redo the controller configuration in EmulationStation (restart first)
                sudo reboot
                FBNeo rom filtering
                Mame2003 Arcade Bezels
                Fba Arcade Bezels
                Fba NeoGeo Bezels
                  kudaba
                  Which emulators are you using? Does it work in any emulators or just some. I know PiSnes needs some manual configuration, the default setup doesn't work.
                  https://github.com/retropie/retropie-setup/wiki/super-nintendo-entertainment-system#pisnes
                    jokey carrot @Sébastien
                    @Sébastien try turn of the mapping hack that did the trick for me
                      Strik9ine
                      Did any if this help? I've got the same issues.
                      • N
                        neonlightning
                        i know this is old. but did anyone ever solve this. i've encountered it with both my zero and fc30pro
                        sirhenrythe5thS L 2 Replies Last reply Reply Quote 0
                        • sirhenrythe5thS
                          sirhenrythe5th @neonlightning
                          I just bought a FC30pro, set it to Android-Mode and hooked it up in Bluetooth-Settings.
                          It works perfect, no Problem.
                          Only thing that is a bit odd...it did not reconnect at first.
                          Then i set the connection to "Boot" and even if i unterstand this the way the Bluetooth Connection starts only on Boot process, the Pad connects at anytime 😲.
                          Well, dont unterstand this, but it works and its great!
                          Had not to use the hack or udev-rules, just connect and that was it.
                          RetroRatio: 1.88
                          Started Games beaten: 2,47%
                          Site Rank: 4382/93743 ranked users (TOP 4.76%)
                          Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
                          • L
                            lesk @neonlightning
                            @neonlightning
                            The 8bitdo controllers have different pairing modes.
                            https://retropie.org.uk/forum/post/149216
                            This worked for me!
