    Mario Kart 64 item issue
    n64mario kart 64itemissuebug
    18 Posts 5 Posters 9.7k Views
    • Capt_MorganCreekC
      Capt_MorganCreek
      While playing several rounds of Mario Kart 64 I encountered a really annoying item issue. Sometimes if you've got an item and you are hit you can no longer use an item, so you are stuck with the item you have until the race is finished. In the next race it's fine again.
      The chance of catching this bug is higher in multiplayer and it seems to happen when you have an item and you get hit by other items or drivers. Did somebody else encounter this issue?
      The Z-trigger works fine and it happened in lr-GlupeN64 and mupen64plus (the video plugin does not matter).
      The version of lr-GlupeN64 is 1.3.6 - GlupeN64 GLES2 2.5 7b7cb25 and for mupen64plus the version you get with the retropie 4.1.14 setup script. I'm running a Pi3 with retropie 4.1 and the Mayflower/Hiujia N64 to USB adapter.
      RetroPie64 - My Nintendo 64 conversion: https://retropie.org.uk/forum/post/55927
      markyh444M 1 Reply Last reply Reply Quote 1
      • markyh444M
        markyh444 @Capt_MorganCreek
        @Capt_MorganCreek Could be a dodgy version of the ROM. Maybe try getting hold of a different one from somewhere else and try that one?
        Retropie in a PSX - Pi3
        Capt_MorganCreekC 1 Reply Last reply Reply Quote 1
        • Capt_MorganCreekC
          Capt_MorganCreek @markyh444
          @markyh444 That's a good idea. I tried a new rom and had no issues yet in SP, will test out MP later and check if it happens again.
          • markyh444M
            @Capt_MorganCreek glad that suggestion seems to have helped. With you using multiple emulators, but was getting the same result just left the ROM as the common factor.
            • SwampyS
              Swampy
              I also have the same problems with the items. Two days ago I played with my girlfriend.
              We have the same issue with multiplayer. Did you have success with changing the rom?
              And if yes, which rom did you use?
              I didn't have this problem before. But I don't know when it started.
              I always updated the retropie-script and the emulators. I am also using two xbox360-controllers with the xpad-driver.
              Linux is like wigwam: no Gates, no Windows and Apache inside.
              Capt_MorganCreekC 1 Reply Last reply Reply Quote 0
              • Capt_MorganCreekC
                Capt_MorganCreek @Swampy
                @Swampy I had no chance yet to play it with my girlfriend in MP, but it did not happen to me in SP. I'll let you know as soon as I tried it again.
                SwampyS 1 Reply Last reply Reply Quote 0
                • SwampyS
                  Swampy @Capt_MorganCreek
                  @Capt_MorganCreek Thank you! Which version of the rom do you use?
                  • Capt_MorganCreekC
                    @Swampy I use the European version 1.1.
                    • Capt_MorganCreekC
                      Capt_MorganCreek
                      I tried it again today using the new lr-mupen and it happened again in 2 -player racing mode.
                      I couldn't replicate it in singleplayer at all, so the problem seems to be multiplayer-exclusive. The way I tested it was finishing the race with player 2 and switching over to player 1. I had two controllers attached, so I just had to grab a different controller. After a few successful itemdrops it happened again and it seems to be completely random. I wasn't hit by anything and there wasn't anything else that would stand out.
                      Since it happened with different roms and all the emulators are based on mupen64plus I'm pretty sure it's a bug in the emulator :(
                      • SwampyS
                        @Capt_MorganCreek I updated mupen64plus from source and updated the x-pad driver.
                        I also use the European version 1.1 (1.0 before).
                        Today my girlfriend played in single-player mode and it worked. No problems.
                        Then we tried to play together and it happened again! The issue began, with the third extra of my girlfriend.
                        She was not able to use it. For me all worked. At the next race the same problem.
                        No more ideas, what the problem could be.
                        Nobody else with this problem?
                        Capt_MorganCreek, do you also use a xbox360-controller with xpad?
                        • Capt_MorganCreekC
                          @Swampy I use a Hiujia/Mayflash N64 to USB adapter and mapped it via xboxdrv. In my tests it happened with either player, but more often to player 2.
                          • SwampyS
                            Swampy
                            OK, that means it's not a problem with the controller.
                            I also think it's an mupen64plus problem.
                            Should we open an issue in https://github.com/mupen64plus/mupen64plus-user-issues/issues ?
                            But first we should exclude, that it is not another problem.
                            • SwampyS
                              Swampy
                              Sorry, I saw you've already done it:
                              https://github.com/mupen64plus/mupen64plus-user-issues/issues/686
                              Well described, thank you!!!
                                mortosaur @Capt_MorganCreek
                                @Capt_MorganCreek at the weekend I was playing 3 player for the first time. I had already seen the issue with unusable items in two player races (it always seems to be one of the boost items for me) but in three player battles all the players drive off without their balloons. This means that even if you are hit, you cannot ever die. All players were immortal. If you drive back to your starting position the balloons are still there, just half sunk into the floor. I haven't tried a different ROM yet but i'm guessing the issue stems from the same thing as this?
                                • Capt_MorganCreekC
                                  Capt_MorganCreek @mortosaur
                                  @mortosaur That's actually a different error. It happens to me as well, but I guess it's just a graphical glitch since after 3 hits the round end. At least in my case. I encountered this glitch in different emulators.
                                  • SwampyS
                                    Swampy
                                    I looked a little bit into the mupen64plus github.
                                    Have you tested it with the US rom?
                                    • SwampyS
                                      Swampy
                                      I have tested it with my girlfriend and the item error seems to disappear.
                                      I used the US rom (Mario Kart 64 (U) [!].z64).
                                        A Former User
                                        European ROMs are very weird with emulators. It's best you use the American version.
