    SD card memory
    sd formatroms on networkmemoryhelp
    3 Posts 2 Posters 1.2k Views
    • H
      harriszilla
      I tried transferring roms through my network and I'm getting an "exceeding a user disk quota" message. So I'm guessing my card is full, but I know there's no way I can be close to being maxed out. It will not let me expand the memory through retro pie due to running noobs. Is there another way to expand the size without having to reformat and lose everything? Using a 32gb sandisk with pi3 and up to date retropie.
      • markyh444M
        markyh444 @harriszilla
        @harriszilla I did a quick Google and found this forum post about partition resizing with Noobs: https://www.raspberrypi.org/forums/viewtopic.php?t=111325&p=763825
        Looks like it's awkward and more involved than using the raspi-config menus though...
        Retropie in a PSX - Pi3
        • H
          harriszilla @markyh444
          @markyh444 Thanks a bunch! I read through it and it does look very tricky. I'm thinking it may just be easier to do a fresh install to be on the safe side. Thanks again!
