    Phase Shift (Guitar Hero clone) via Moonlight Embedded
    rpi3guitar herophase shiftmoonlight
    7 Posts 3 Posters 4.1k Views
    • H
      HarmLTC
      I've setup Moonlight Embedded on Retropie/Emulationstation using different guides and i am very happy with the results. My X360 controllers are recognized and i can navigate every menu. When launching Moonlight Embedded (stream PC/Steam) i can still navigate menus and play games without any problem. Great!
      The next step was to look for a rhythm game like Guitar Hero, and was found in the form of Phase Shift (http://www.dwsk.co.uk/index_phase_shift.html). Installed and worked like a charm. X360 guitar controller worked out of the box by connecting the USB wireless receiver to my PC (which i also use to my RPI3). Added the game to Steam so it can be launched by EmulationStation/Moonlight.
      Now, when my X360 guitar controller is connected to my RPI3 using the wireless receiver, i can navigate all the menus in EmulationStation, all the menus in Moonlight/Steam, but when i launch Phase Shift the game freezes when i touch a button. Normal X360 controllers work fine in the game.
      I know this might be a Phase Shift problem, but in the forums over there they couldnt really help me because they dont use this setup, so thats why i try it here. Also, Phase Shift looks like a great game to play from your couch using RetroPie, so it might interest others to help!
        backstander @HarmLTC
        @HarmLTC
        I've never tried Phase Shift but I have played Frets on Fire on my PC back in the day. It was alot of fun! The only problem is that FoF was last updated in 2008.
        This sounds like a Phase Shift issue. I've tried many games I own in Steam and some work and some have issues. I've only tried a couple of non-Steam games add to Steam and they seamed to have issues with Moonlight. An example is I tried Uplay's version of Assassin's Creed in Steam using Moonlight and it wouldn't recognize my Xbox 360 controller (it had @ signs in all the controller mapping). Some other game everything worked but the sound (sound was coming from my PC speakers instead of my RetroPie/TV).
        One thing you might try is in GeForce Experience program on your PC, add Phase Shift's installed folder to the search path (Like C:\Games\Phase Shift or whatever).
        • H
          HarmLTC
          Unfortunately, this didn't work.
          So it is possible to stream and play Phase Shift through Moonlight and control it with a keyboard or X360 controller, but not with the X360 Guitar Controller.
          I think i should continue my search on the DWSK - Phase Shift forums.
          meleuM B 2 Replies Last reply Reply Quote 0
            meleu @HarmLTC
            @HarmLTC I'm not familiar with these Steam/Moonlight things and I can't help with it, sorry. But as a hobbyist drummer I'm very interested in running Phase Shift on a Raspberry Pi.
            The only Windows machine I have is a Intel Compute Stick used only to play drums running Phase Shift (to be honest I use DTXMania as well).
            If you make any progress on it, please share with us! And then my home could become 100% Windows-free! :-)
              @HarmLTC
              Did you map the Xbox360 Guitar for Moonlight support?
              moonlight map xbox360guitar.map
              You might have to make this directory but I keep my Moonlight controller map files in /opt/retropie/configs/moonlight then when you launch Moonlight you just tell it where you controller map files is with -mapping /opt/retropie/configs/moonlight/xbox360guitar.map.
              You might already know this but letting you know just in case!
                backstander @meleu
                @meleu
                So you're a hobbyist drummer as well! Seems like most musicians I have meet are guitarist but us drummers are very rare lol. I think it's been like 5 years since I've really been able to drum in a band though :-\
                • H
                  HarmLTC
                  I didn't map the X360 guitar controller before, because it was already working in EmulationStation and in Moonlight as well. I could navigate all the menus and select my games.
                  Now I did map my guitar controller and launched the game, but the problem persists. It seems, more and more, that this is a Phase Shift issue.
