    nescasediybuildtheme
    1.3k Posts 210 Posters 3.4m Views
    • TMNTturtlguyT
      TMNTturtlguy @Syhles
      @Syhles can you send the carousel info my way as well. I tried testing the feature supported on my build and it did not work properly for one of the older ES builds, so I didn't implement any of it at this time. I might have done something wrong on my end though as i couldn't find a good wiki on what is supported with the carousel coding either. Thanks!
      • ruckageR
        ruckage @Syhles
        @Syhles
        Do you have a link to the forum where they're working on the carousel mod as I'd like to read up on it (would save me hunting around for it)?
        I'm running Retropie on a raspberry pi 3 and and a raspberry pi 2 (but doing most of the theme testing on my PC). I have a rpi zero as well but need a few adapters before I can set that up.
          Syhles @TMNTturtlguy
          @TMNTturtlguy
          Yeah give me a second to pull out and boot my laptop.
            Syhles
            @ruckage
            https://retropie.org.uk/forum/topic/2696/input-needed-es-theming-improvements/145
            It has like 200 posts have fun, lol.
            I run it on a laptop with Ubuntu.
            I have another suggestion for the theme after the rest of the work is done on it.
            • ruckageR
              ruckage @Syhles
              @Syhles
              Thanks, I appreciate it. That will keep me busy reading for a while :)
                Syhles @ruckage
                @ruckage
                The XML commands change later on in the thread.
                • ruckageR
                  ruckage @Syhles
                  @Syhles Thanks. I'm reading it in reverse order at the moment.
                    Syhles @ruckage
                    @ruckage
                    If you don't care I'm going to post example code for the two styles of carousel in the thread for @TMNTturtlguy
                    • Serj TargarienS
                      Serj Targarien
                      After reading through the carousel thing now I'm curious. What is stopping us from themeing the menu you get when you press start?
                      If both the carousel and that menu could be modded we could at last have fully cohesive themes and our RetroPie setup would look much better in my opinion. The only thing that actually detracts from any pixel theme feeling as pixelly as it should are both the start menu and the "x games avaliable" text not being pixelly at all.
                        Syhles @Serj Targarien
                        @Serj-Targarien
                        With the carousel code you can choose your own text for the Games Avaliable list. So all @ruckage needs to do is use his nes font and pixelly theme all around besides the menu.
                        As far as I know the only thing stopping us from themeing the menu is code being added to emulationstation that allows us to do it.
                        Serj TargarienS 1 Reply Last reply Reply Quote 0
                          dankcushions Global Moderator @ruckage
                          @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          @dankcushions said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          It has now been added to the retropie theme installer, so you can install/update via that if you 'Update RetroPie setup script'. :)
                          That's great, thanks :) . As @Serj-Targarien said, how do updates work with the theme installer? Will it automatically get updated when I make changes to my git repository?
                          yes! after you have installed a theme, you can 'update' it which is just pulling in the latest version from git. as long as you keep to the same git repos, users can update directly from the theme installer :)
                          • ruckageR
                            ruckage @Syhles
                            @Syhles said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                            @ruckage
                            Sure, go ahead. As long as the thread doesn't get turned into the Carousel discussion thread :P
                            I have to say my only real gripe with this forum is the lack of a PM function, it makes communicating with individual members pretty much impossible.
                            @Serj-Targarien said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                            With the carousel theming you can change the font on the 'games available' (it will be the first thing I do). I'm sure the menu could also be themed but someone would need to modify the code. Probably best to ask in the thread @Syhles linked to. Personally I would prefer the gamelist bugs to be fixed first though (I'm starting to sound like a broken record now - I'll try to stop mentioning the gamelist bugs :P)
                              Syhles
                              @TMNTturtlguy
                              <carousel name="systemcarousel">
                              	<type>horizontal</type>
                                    	<pos>0.5 0.6</pos>
                              	<size>0.5 0.20</size>
                              	<color>FFFFFFff</color>
                              	<logoScale>1.5</logoScale>
                              	<logoSize>0.10 0.3</logoSize>
                              	<maxLogoCount>3</maxLogoCount>
                              </carousel>
                              	<type>vertical</type>
                              	<pos>0.025 0.05</pos>
                              	<size>0.33 0.7</size>
                              	<color>4ca0ad75</color>
                              	<logoSize>0.20 0.15</logoSize>
                              	<maxLogoCount>5</maxLogoCount>
                              </carousel>
                              <text name="systemInfo">
                              	<pos>0.65 0.82</pos>
                              	<size>0.3 0.12</size>
                              	<backgroundColor>3bc5db75</backgroundColor>
                              	<fontPath>./art/font.ttf</fontPath>
                              	<fontSize>0.033</fontSize>
                              	<color>0f363dff</color>
                              </text>
                              This is from @Zigurana 's
                              dev.xml that was posted.
                              I currently don't have the <feature supported> code but from what I remember is if you already have the video <feature supported> just use that and replace video with carousel. Just make sure only the Carousel stuff is inside of <feature supported> or you will break the rest of the stuff that inside that block.
                              • Serj TargarienS
                                Serj Targarien @Syhles
                                Thanks for the heads up, I hope that piece of code ends up being added.
                                I know there are other Frontends being coded at the moment to get around the lack of customization in EmulationStation, but i personally love the simplicity and usefulness of it, and hope to have it fully themed in the future.
                                @dankcushions, so we have to remove the theme from /opt/retropie/configs/all/emulationstation/themes and then install it through the theme installer, right?
                                EDIT: Never mind, already done that.
                                • TMNTturtlguyT
                                  @Syhles thanks, to be polite I won't comment more on this string as it is for an awesome theme! I use the code you posted but also didn't have the carousel feature. So I tried my own and it didn't work. I could have had an error though.
                                    Syhles @ruckage
                                    @ruckage
                                    I'd like to be able to use all of the metadata image fields in detailed view besides the video, video on the system(carousel), themeable menu, the extra sounds that are available to recalbox, and favorites like recalbox does it.
                                    This is super off topic but no one in my house is interested in this so...
                                    • kromebellyK
                                      kromebelly @ruckage
                                      @ruckage Thank you! That fixed it.
                                      • ruckageR
                                        ruckage @Syhles
                                        @ruckage
                                        I'm sure those features will be added in time as lots of people would appreciate them (particularly the extra metadata images). I was quite upset myself when I realized most of the sounds didn't work in current ES. I'd also like animated gif support in some form (with transparency) as that would allow lots of fun possibilities.
                                        • ruckageR
                                          ruckage
                                          I've been experimenting with the new carousel theming and I'm thinking of going for something like this.
                                          It will require making each of the system logos individually but I should be able to get them all done in a few days (the hardest part is finding good photos of box art). As these would look odd as logos in the old version of ES I think I should be able to use the 'feature' tag so that these are only used on the new version that supports carousel theming.
                                          mediamogulM T DarkWolfD RompeR 4 Replies Last reply Reply Quote 7
                                            mediamogul Global Moderator @ruckage
                                            @ruckage
                                            It gives it a more corporate/conservative look, but I don't think that's necessarily a bad thing. What box type images do you plan on using for non-system menu items, such as Ports, RetroPie and Arcade?
