    nescasediybuildtheme
    1.3k Posts 210 Posters 3.6m Views
    • ruckageR
      ruckage @mattmanforever
      @mattmanforever said in Cardboard Mini NES + Nes mini and Famicom mini themes:
      @ruckage Working great now, thank you so much. This is VERY nitpicky, but is it possible to get the US Super Nintendo instead of the Super Famicom on the system icons? Sorry if this has already been asked. I might be the only weirdo who preferred the US version.
      We're not all 'Murrican you know ;)
      I'm from the UK and that is what our Super Nintendo looked like (as well as most of the world in fact). I will however be adding an alternative USA SNES icon but the current icon will remain the default.
      p.s - I can confirm that you are a weirdo for preferring the US SNES design ;)
        mattmanforever @ruckage
        @ruckage Hahaha I know, I know. It's all due to nostalgic reasons. I have the 'Merican 8bitdo controllers too. Glad to hear there will be an alternate I can switch out. You rock.
        • HexH
          Hex
          @ruckage Can you test the NES-mini for Gameboy system. I am getting a bad layout
          Imgur
          • ruckageR
            ruckage @Hex
            @Hex said in Cardboard Mini NES + Nes mini and Famicom mini themes:
            Imgur
            I can't replicate that at my end (tested on pc and raspberry pi 3). Can you give more info - is it just gameboy that's affected? What layout/resolution settings have you set?
            • ruckageR
              You're not the first to ask so I've made alternative SNES US icons. They will be in the next updates. I'll put them below as well though so you can use them straight away if you want.
              M 1 Reply Last reply Reply Quote 2
                @ruckage You made my day. Thanks for doing that so fast!
                • HexH
                  Hex
                  @ruckage Running on Linux Latest ES and Latest NES-mini
                  only gameboy is affected. rest work as expected. I think the gamelist might have some problem. I will check it out and let you know. Resolution 1920x1080
                  • ruckageR
                    ruckage @Hex
                    Okay. There shouldn't really be any reason for a single system to display incorrectly as the theme.xml is almost identical for every system (mainly just colour differences). If you find out what the cause is let us know as it may help others.
                      momaw27 @ruckage
                      @ruckage
                      On it, thanks man!
                      Look for a report shortly.
                      • HexH
                        Hex
                        @ruckage Having a video tag causes this problem.
                        • ruckageR
                          ruckage @Hex
                          Ah, that would explain it as I haven't added video view yet. I will sort it out so that it at least displays in video view correctly but you should just be able to switch view to detailed in the ES ui to make it display for now.
                            momaw27
                            Hey @ruckage !
                            It works!!!
                            Thank you very much!
                            I had to uninstall the theme and then reinstall (update wasn't reflecting the changes for some reason).
                            But... it works great!
                            Looking forward to the NES-Mini update!
                            • HexH
                              Hex
                              @ruckage Another thing while you are at it, Config should have 2017 as year dont you think. And please add support for Dos soon Thanks for all your work
                              • ruckageR
                                ruckage @Hex
                                Not really as that's supposed to reflect the release date of the console/computer and config is neither. I think I'm just going to remove the year box completely from config and arcade based systems as it seems to be causing confusion (no doubt then people will be asking why no 'year box' appears on those icons (◔_◔) )
                                • ruckageR
                                  ruckage @momaw27
                                  @momaw27 said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                  Hey @ruckage !
                                  It works!!!
                                  Thanks, glad it works.
                                  Regarding needing to uninstall the theme - did you restart ES as I think changes aren't seen unless the theme is reloaded.
                                    momaw27 @ruckage
                                    @ruckage
                                    I did not. I bet that was the deal :)
                                    • SystemLogoffSAS
                                      SystemLogoffSA
                                      Oh, if it's not too much trouble, can you add official support for 1366 x 768? I can make a small change each update, but I can't get it perfect like the other ones are.
                                      No worries if it's too much work for an edge case. :)
                                      • ruckageR
                                        ruckage @SystemLogoffSA
                                        @SystemLogoffSA said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                        Sure, I'll add that as an option.
                                          astoufu
                                          @ruckage
                                          Hello, could u give me a link to download one older version of Famicon Mini Theme?
                                          I am using emulationstation on Windows and i can't get it to work with the last version of theme. I have the older NES mini version and it works perfectly.
                                          Thanks for the work, it's amazing!
                                          • ruckageR
                                            ruckage @astoufu
                                            @astoufu said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                            @ruckage
                                            Can't you just use a more up to date version of EmulationStation? @jdrassa posted a windows build of the latest version a few days ago: Click Here.
