    help setting up a static ip address?
    networkip addressstatichelp
    14 Posts 8 Posters 12.8k Views
      coolstuff
      Hello!
      I've had my raspberry pi setup with retropie for a couple of months now, and I've never been able to work out how to get connected to my wifi. I tried ethernet, which didn't work for whatever reason and I tried wifi but this tutorial is far too confusing for me, if anyone could help me set it up, it would be greatly appritiated.
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) B+
      Power Supply used: (If using a Pi) N/A
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.1
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) retropie-4.1-rpi2_rpi3 (1).img
      USB Devices connected: xbox 360 wired controller, apple keyboard
      Controller used: xbox 360 wired controller
      Error messages received: N/A
      Log found in /dev/shm/runcommand.log (if relevant): N/A
      Guide used: (Mention if you followed a guide) https://github.com/retropie/retropie-setup/wiki/Wifi#static-ip
      File: (File with issue - with FULL path) N/A
      Emulator: (Name of emulator - if applicable) N/A
      Attachment of config files: (PLEASE USE PASTEBIN.COM FOR LARGE LOGS) N/A
      How to replicate the problem: N/A
        snowcherry
        What exactly happens when you try to use the wifi menu to connect?
          coolstuff
          My wifi is weird, it has been for a while. I have to manually input the ip address for every device I try to connect, normally ethernet works fine but since it hasn't worked this time I'm pretty lost. Anyway, back to the question, it does connect but the IP is not displayed and I am unable to use the internet (if that makes any sense).
            snowcherry
            Maybe the DHCP on your router doesnt work correctly. Go to your router config page and see if you can enable DHCP there.
            • AlexMurphyA
              AlexMurphy Banned @coolstuff
              @coolstuff Which wifi dongle are you using? You are using one, right...?
                coolstuff @AlexMurphy
                @AlexMurphy Wait.... what? I could have sworn I read that the b+ had built in wifi? Either way though, that doesnt explain why ethernet doesnt work.
                • AlexMurphyA
                  @coolstuff No wifi until The Pi3 I'm afraid! type ifconfig in the terminal, do you see eth0 listed? Post what it says here.
                    snowcherry
                    If you're NOT using a Pi 3, then you should also download the Retropie image for the Pi 1.
                    • W
                      willieaames
                      Try
                      sudo dhclient -r
                      Followed by,
                      sudo dhclient
                      Or do: sudo dhclient -r wlan0, sudo dhclient wlan0
                      This (should) renew the dhcp lease and assign one of your PIs to a new IP.
                        coolstuff
                        Ok so... I found out from the friend I got my pi from that it is in fact a pi 3 model B so it DOES have onboard wifi.
                        @willieaames said in help setting up a static ip address?:
                        Try
                        sudo dhclient -r
                        Followed by,
                        sudo dhclient
                        I tried this, but it didn't seem to help
                        @AlexMurphy said in help setting up a static ip address?:
                        I see eth0 listed, It doesnt have anything like an IP there... I dont know how to copy and paste from the pi and paste it here, so I took a picture: 0_1487779385049_IMG_0203.JPG
                          BuZz administrators
                          Static address on Raspbian Jessie -
                          https://nebulousthinking.wordpress.com/2016/02/25/setting-a-static-ip-for-raspbian-jessie-in-2016/
                          https://www.jeffgeerling.com/blog/2016/setting-static-ip-address-raspbian-jessie-lite-on-raspberry-pi
                          • herb_fargusH
                            herb_fargus administrators
                            btw I've updated the wiki after testing it myself and getting it working.
                            https://github.com/RetroPie/RetroPie-Setup/wiki/Wifi#static-ip
                            • I
                              iamjenny
                              Try
                              sudo dhclient -r
                              Followed by,
                              sudo dhclient
                              This guide can be useful if you want to renew dhcp and assign your pls to new IP
                                I just told my DHCP server to assign the same IP address to the Pi's MAC address.
