    Kodi won't work on my 1280x1024 monitor but emulators do.HELP
    kodi retriopikodi issue
    10 Posts 4 Posters 2.4k Views
    • F
      Freko
      Hi Sorry to jump in on this post but I have been trying to get Kodi to work on my pi3 retropie image,I have it setup to an old HP monitor max resolution 1280x1024 via a HDMI to VGA adaptor all the emulators work fine but when I try to open kodi it has a white box moving round the screen set resolution to 1280x1024.
      I did change the config.txt file to mode 2 and group 35.
      Kodi does not seem to like it.
      Is there a way to edit the kofi config to change to a resolution that will work.
      This is my thrid day ,now pulling my hair out,I was able to get into kodi settings once and I changed the resolution to 1280x1024 by pressing a button on my gamepad when the white box comes on screen just before kodi is to start,but now I don't get the white box and have to sgut down the pie as it hangs with a blank sreen.I have uninstalled kodi and reinstalled a few times in optional package manager.
      I hope you find the time to help me with this problem.
      Many Thanks.
      Freko...
        BuZz administrators @Freko
        @Freko you can try removing any existing Kodi configuration by removing /home/pi/.kodi and it might default to the current mode.
        • F
          Freko
          Cheers I will try that tomorrow.
          Thankyou for the reply.
          • F
            Freko @BuZz
            @BuZz Hi again, what do I type to remove /home/pi/ .kodi
            After removed should I just reinstall kodi in manage optional packages ?
            Cheers.
            Lyle_JPL 1 Reply Last reply Reply Quote 0
            • Lyle_JPL
              Lyle_JP @Freko
              @Freko
              rm is the command to delete files. It works like del in DOS. Don't re-install Kodi, just restart it and it will create a fresh default .kodi file.
                pjft @Lyle_JP
                @Lyle_JP @Feel I believe it's actually a folder. Since I still haven't figured out a proper way to delete a folder and everything in its tree recursively, you may try to move it instead.
                mv .kodi .kodi-bak
                Lyle_JPL BuZzB 2 Replies Last reply Reply Quote 0
                • Lyle_JPL
                  Lyle_JP @pjft
                  @pjft rmdir will delete a directory, but only after it is empty.
                    BuZz administrators @pjft
                    @pjft rm -rf can delete a directory and everything under it (be careful with this command).
                      pjft @BuZz
                      @BuZz @Lyle_JP would that have come in handy quite a few times so far :)
                      Coming from DOS, I missed an equivalent to deltree, and I suppose I tried to cope with it via alternate means. This will help for sure.
                      Always learning! Thanks both.
                      • F
                        Freko
                        Got it sorted ,I plugged the raspberry pi3 into my HD TV and the screen was able the handle the default 1920x1080 resolution.Then went into Kodi settings and set the resolution to the nearest to 1280x1024 which was 1280x720.
                        Another leason learned on the Pi.
                        Thanks guys for all your help and support.
