    Best way to output SCART (RGB) from Pi 3?
    scartrgbcsyncpvm
    92 Posts 15 Posters 69.7k Views
      danfun @Dalton69
      @Dalton69 I already have those onstart and onend scripts. I can only find the framebuffer resolution in the config file and I've already changed that...
        A Former User
        It's a bizarre behaviour, I've never seen the in-game menu behave like that, in my case it always corresponds to the game resolution. This was problematic when the game itself was shrunk - before editing the custom_viewport and/or aspect/integer - I could only read the menu then because of my huge 29" display. Or, when the resolutions were going into 2x (or higher) mode, the menu was super stretched then and unusable.
        I also recently "updated" through wifi but nothing has changed.
        So, if you're saying that the game displays fine while the menu is messed up then I haben't a clue what's the reason. Recommend starting from scratch with a clean image/settings.
          danfun @A Former User
          If it helps, this is how it looks. Very stretched out vertically but also a little horizontally.
            Dalton69
            Well I would say it's due to the fact you have aspect ratio = core provied. It should be custom so if you try the retroarch.cfg settings I posted for say Nes or change it to whatever system you are having issues with and then set the appropriate custom_viewport_width and custom_viewport_height then it should be fine provided that you have 1600px set in the onstart script.
            I can also see that you are trying to use the psx emulator, is that the only one having issue or all emulators?
              A Former User
              This post is deleted!
                danfun @Dalton69
                @Dalton69 that was changed to custom aspect shortly after the screenshot, but it still looks the same. Regardless of what emulator I use it looks like that.
                  A Former User
                  It doesn't really look just stretched - more like elements are all over the place.
                  Maybe try different theme in ES. I'm using Pixel-TFT, heard other ones have problems.
                    Dalton69
                    Strange indeed but must be something with the set up then and the different files. Are you using the lastest 0.6.8 version of the onstart script? Also please post the content one of the retroarch.cfg for any of the systems you are having issues with then we can take it from there.
                      A Former User
                      Okay, so I'm facing the final frontier regarding 1600 px hack (using Pi2SCARt+ CRT TV) - vertical MAME games. The horizontal ones are mostly fine. I'd like to display the vertical ones properly , without having to turn my 50kg TV on the "length" side every time.
                      Problem is, the vert resolutions are bigger than the 240 that's in my config now, so even though horizontally they scale properly while in 1:1, there are big chunks missing on the top and bottom. I've been told by Grandmaster Fudoh himself to "put the Pi in 480i mode" so the vertical stuff would fit. I know that black bars on both sides are inevitable in this setup, but I can live with that.
                      I'm not quite sure how to go about this though. I assume it involves preparing a separate SD card with new config just for that - PITA, but the cause is worth it. What values do I change? I assume it's got to be the ol' hdmi_timings and dpi_mode/group?
                        Melvin.FoX @maxriptide
                        @maxriptide said in Best way to output SCART (RGB) from Pi 3?:
                        that sort of converter (HDMI-VGA) introduces a slight lag so
                        maxriptide what kind of lag do you mean - something like playing on LCD or more?
                        I have already build arcade stick and looking for a way to connect it to CRT so my idea was to use this converter and UMSA not to redevelop or make any mods of my project. Could you give me some more detail?
                          maxriptide @Melvin.FoX
                          @melvin-fox, it is nowhere like LCD lag. We're talking about approximately 06 ms I come up with manual test input lag of 240p Test Suite (which is a subjective test) in the pc engine emulator. It might be due to the cheap HDMI-VGA adapter I was using.
                            Melvin.FoX
                            Great, many thanks for the answer! :D I am going to hook up my RPi with HDMI -> VGA and VGA -> Scart so I got scared as I already ordered proper adapters and haven't even thought about it :P
                            I will try to give some update as soon as I got some time to test it (it would need additional RPi settings to be changed so probably it will take me some time).
