    Custom build inside a joypad
    pizeroxbox controllerps1ps2dual shock
    3 Posts 2 Posters 1.3k Views
    • Z
      ZombieMedia
      I was looking at the the custom build where someone had put a pi zero into an XBOX controller. It got me thinking. Is that possible in a PS1/2/3 controller? I know the XBOX pads were huge, but could you fit a zero in a DualShock?
      • HurricaneFanH
        HurricaneFan
        I don't know how much extra room you'd have but here are the specs I've seen online:
        The pi zero is 65mm long x 30mm wide x 5mm thick
        PS1 Controller is 157 mm × 95 mm × 55 mm
        PS2 Controller is 157 mm × 95 mm × 55 mm
        PS3 Controller is 160 mm × 97 mm × 55 mm
        • Z
          ZombieMedia @HurricaneFan
          @HurricaneFan
          Thanks. I may look further into this :)
