    Help with audio on HDMI
    helphdmi audiohdmiaudioaudio issues
    4 Posts 3 Posters 1.6k Views
    • N
      NinjaX567
      Im trying to hook up my Raspberry Pi 3 on my Philips TV with a HDMI cable. I got Jet Set Radio on Dreamcast with audio for some reason, but no sound in any other game, regardless the console. I tried all of the config.txt fixes, but none have worked. Please help.
      • FloobF
        Floob
        Did you try all the tips here?
        https://retropie.org.uk/docs/Sound-Issues/
        Can you try on a different TV for comparison?
        N edmaul69E 2 Replies Last reply Reply Quote 0
        • N
          NinjaX567 @Floob
          @Floob I hooked up on another TV, same problem.
            edmaul69 @Floob
            @Floob @NinjaX567 after one of the new updates i no longer get audio in dreamcast either. Its only in dreamcast. I havent tried composite audio to see if it works on it.
