    Documentation help
    documentationwikihelp guide
    6 Posts 4 Posters 2.2k Views
    • FloobF
      Floob
      Hi,
      I'm sure this is a daft question, but how do we contribute to the new docs area?
      https://retropie.org.uk/docs/
      Or is the Wiki still being maintained/updated and elements copied across?
      https://github.com/retropie/retropie-setup/wiki
      mattrixkM herb_fargusH 2 Replies Last reply Reply Quote 1
      • mattrixkM
        mattrixk @Floob
        @Floob I think the new Docs are just a copy of the existing wiki. I think they just update however often.
        • herb_fargusH
          herb_fargus administrators @Floob
          @Floob yes they are more or less the same, the pretty docs are just a mirror of the wiki
          Jools integrated a module that builds the pretty docs from the wiki. I can run it manually and it will autogenerate the docs (an SSH key to the retropie server is required). We have considered automating it but have decided against it for now in case someone does something stupid on the wiki, there are also some bugs with the default markdown parser so I'm running a patched parser on my PC until those bugs are fixed upstream.
          I get emails anytime the wiki is updated and I generate the docs at least weekly.
          There is a config file that defines the pagination here: https://github.com/RetroPie/RetroPie-Docs it also includes some CSS/ custom configs for the layout
          meleuM 1 Reply Last reply Reply Quote 3
          • FloobF
            Floob
            Great stuff, thanks for the confirmation.
              meleu @herb_fargus
              @herb_fargus Are there docs in retropie.org.uk/docs that aren't present in the wiki?
              I've found a broken link in https://retropie.org.uk/docs/Controller-Configuration/ and searched in the wiki to fix it, but didn't find.
              The broken link is in this paragraph:
              You can also configure controls for individual systems and individual games. For more advanced controller configuration with libretro cores (any emulator that starts with lr) see the RetroArch-Configuration page.
              The link points to .../retroarch-configuration but the correct is .../RetroArch-Configuration. Yes, the only difference is the capital letters R, A and C. By the way, I didn't even know that URLs were case sensitive!
              • herb_fargusH
                herb_fargus administrators @meleu
                @meleu said in Documentation help:
                Yes but some I intentionally left out
                Must have missed it will fix when I find a moment
