    problems to install 4.2 for raspi1
    raspberry pi 14.2buginstall error
    8 Posts 3 Posters 2.5k Views
      • downloaded the retropie-4.2-rpi1_zero.img.gz from the official website to install it on my raspi1.
      • checked the md5sum and it's fine.
      • extracted the .img file from the .gz file.
      • copied the .img to the sdcard using dd:
      sudo dd bs=4M if=retropie-4.2-rpi1_zero.img of=/dev/mmcblk0 status=progress
      • dd finished with no failures, put the sdcard on the raspi1 and turned it on.
      • raspi1 boots and show the "Resized root filesystem. Rebooting in 5 seconds..." message and reboots. And this step repeat infinitely.
      • copied the img to the sdcard using dd bs=1M as suggested in the Raspberry Pi official instructions.
      • same problem.
      • copied the img to the sdcard using the Etcher program.
      • same problem
      Unfortunately I don't have other sdcard available to assure that the problem is in the sdcard. But after copying the .img file in the sdcard, and facing that problem on boot, and plugging the sdcard back to my Linux Mint, I can see the partitions retropie and boot, as usually. But I noticed that the sdcard is NOT resized. And this leads me to believe that the problem lies in the resizing procedure. BTW: I'm sure the sdcard isn't "locked" (read-only).
      Pi Model: raspi1 B
      Power Supply used: Samsung Galaxy Note 10.1 AC Charger (output: 5V-2.2A)
      RetroPie Version Used: 4.2
      Built From: raspi1_zero pre made SD Image on RetroPie website - retropie-4.2-rpi1_zero.img.gz
      USB Devices connected: nothing, not even a joystick
      Guide used: first used dd to install the .img file following the official Raspberry Pi INSTALLING OPERATING SYSTEM IMAGES ON LINUX instructions. And after I tried using the Etcher program.
      How to replicate the problem: install the image on a sdcard and try to boot on a raspi1b.
        BuZz administrators @meleu
        @meleu i will look into it.
          meleu @BuZz
          @BuZz just for curiosity, I've tried the 4.1.20 image from your google drive. Same problem.
          BuZzB herb_fargusH 2 Replies Last reply Reply Quote 0
            @meleu other people have used that image without issues i think. Maybe try another sdcard.
            • herb_fargusH
              herb_fargus administrators @meleu
              @meleu I tried the Google drive image with my pi 0 W and it worked fine. A common issue is that USB hubs have caused a hang on boot. Unplug everything but what's necessary to boot then try again.
                BuZz administrators
                Latest image works fine here - so I guess it's an issue with your sdcard or another issue with your set-up.
                  meleu @BuZz
                  @BuZz yeah, it can be the sdcard. I'll try with another one when I have a chance and update the info here.
                  Thanks for the great work!
                    15 days later I finally got enough time and another sdcard to try it again. Confirmed: the problem was the old sdcard. Sorry for the false alarm. Or let's be optimistic, a false positive is better than a real bug. :-)
                    Thanks guys!
