    Retropie upgrade question - What will get "reset" Need user attention after upgrade?
    retropieupgraden64
    5 Posts 2 Posters 1.0k Views
    • TMNTturtlguyT
      TMNTturtlguy
      @administrators Question regarding updating to 4.1.20 - I have my current build running nicely on the last version of retropie. I noticed that changes have been made to the N64 emulators including renaming them. If i do an upgrade of my current retropie, will I need to go into my N64 and reset which emulators each rom uses? Any other settings that might get "reset" during the update? Thanks and excited for the new updates.
      BuZzB TMNTturtlguyT 2 Replies Last reply Reply Quote -1
        BuZz administrators @TMNTturtlguy
        @TMNTturtlguy please do not tag the admins when asking a question. Also no need to post this twice.
        • TMNTturtlguyT
          TMNTturtlguy @TMNTturtlguy
          @TMNTturtlguy Sorry
            BuZz administrators
            It should update any default emulator for the system, but will not update any per rom settings - that will need to be done manually.
            • TMNTturtlguyT
              TMNTturtlguy @BuZz
              @BuZz Thank you
