    My custom SNES/RPI3 build
    snesrpi3custom
    20 Posts 7 Posters 6.8k Views
    • denisuuD
      denisuu
      Hi,
      UPDATE: I sprayed the 3D plate in gray (this build is completly finished now)
      Under the glue in the front there's a TSOP4838 RF receiver for a KODI remote. It work's through the grill and you can't see it from the outside.
      I got 2 nintendo's from the dump but they were very yellowed I bleached them 6 days with retr0bright (Vol 40 12% hair cream).
      I didn't design the 3D printed plate I got it from thingiverse, I used a file to scrape of a little bit of the plastic to make the curve. (actually it should have to be 2mm longer at the top to be perfect) Credit goes to xanderguzman LINK
      The reset button I got out of an old broken computer and I wired the ON/OFF switch to just cut the power. :)
      I got the main image on the SNES cardrige from Deviantart it's the awesome work of TPBarratt.
      Thanks everyone that helped me along the way!
      mattrixkM 2 Replies Last reply Reply Quote 3
      • mattrixkM
        mattrixk @denisuu
        @denisuu Only the last image is showing up for me. The rest are just a grey circle with a bar through it.
        ? denisuuD 2 Replies Last reply Reply Quote 0
          A Former User @mattrixk
          @mattrixk Same.
          • denisuuD
            denisuu @mattrixk
            @mattrixk said in My custom SNES/RPI3 build:
            @itsnitro said in My custom SNES/RPI3 build:
            @mattrixk Same.
            Sorry guy's I moved the pictures it should be fine now. :)
              A Former User
              Ok, that looks amazing.
              One thing; is it just me or why are all of the SNES builds I see are the european versions?
              Oh wait...
              >retropie.org.uk
              But in all seriousness, is there an NTSC SNES build for the Raspberry Pi?
              denisuuD edmaul69E 2 Replies Last reply Reply Quote 0
              • DarksaviorD
                Darksavior
                I hot glued a microsd extender to the expansion slot on the bottom, soldered a 128GB usb stick to a cart, and 4 wires from cart connector to usb. It's doable. My original thought was to have a microsd extender go to the cart but I was having too many issues reading despite soldering good connections. No problems with usb and it's only 4 wires too.
                  Nicely done!
                  • denisuuD
                    denisuu @A Former User
                    Oh wait...
                    >retropie.org.uk
                    Here is one: LINK
                    Ben Heck also did one :)
                    @Darksavior said in My custom SNES/RPI3 build:
                    First I was thinking about putting a 1TB harddrive inside, it would fit perfectly but I'm not sure if it's healthy for the drive to be sideways. Also I would have to add more power probably.
                    Yea it's true I already thought a USB would be way easier!
                    denisuuD 1 Reply Last reply Reply Quote 0
                    • denisuuD
                      denisuu @denisuu
                      @denisuu said in My custom SNES/RPI3 build:
                      What am I saying :P In a PS3 or XBOX one they are sideways too, after a quick google I found out it doesn't matter.
                      The biggest problem is that as soon as I add another HDD I get a lightning icon that my PI doesn't get enough power.
                      • SutterKaneS
                        SutterKane
                        Great work ! Looks very clean and structured (Okaaaaaay, besides the hot glue sculpture in the upper right corner ;-) )
                        But what will you do with an 1TB HD in it ? You will never fill it completely with games, will you ? How about a smaller SSD (needs not that much of power) ?
                        Again: Great work !
                        Rgds,
                        SK
                        • mattrixkM
                          mattrixk @denisuu
                          @denisuu: Okay, that looks awesome.
                          @SutterKane: They could be using it for Kodi, so they could load the hard drive with movies and such.
                          • denisuuD
                            denisuu @SutterKane
                            @SutterKane: Yea I mainly use this for downloading stuff and media center, since the RPI is silent and doesn't use much power.
                            It's like a perfect fit, but I need to find a solution to have the connection stick out. The hard drive is too tick to have it on top.
                            • DarksaviorD
                              Darksavior @denisuu
                              I wonder if heat might be an issue with the hdd inside that plastic...
                              If you're gonna watch stuff at home, why not just stream your media with kodi? I'm dualbooting with Rasplex because Kodi won't decode 10bit videos properly:/. Rasplex just transcodes what the pi won't run natively.
                              • denisuuD
                                denisuu @Darksavior
                                @Darksavior: It's mostly for using it as a permanent Deluge download center I would attach the HDD.
                                I don't think the heat would be too bad, since this HDD came out of an enclosure, I think the biggest problem would be fitting the connector.
                                • denisuuD
                                  denisuu
                                  I made the backplate gray and the sdcard is extended so this build is finished now :)
                                    edmaul69 @A Former User
                                    @itsnitro i made one for a friend of mine. I prefer the famicom/euro snes version myself. I also remember going into a game store and seeing super mario world on a super famicom before the super nes came out. That was a great moment that will stick with me forever.
                                    • denisuuD
                                      denisuu @edmaul69
                                      @edmaul69 I also like the PAL one better! But I'm from Belgium so it also has more nostalgic value.
                                        edmaul69 @denisuu
                                        @denisuu i think the u.s. one is ugly compared to the euro/japanese one. Im not sure why there were so many systems that they changed in the u.s. The turbo grafx 16 was ugly as all hell. The pc engines were awesome. If we had a black version of the pc engine it would have been really cool. Instead we had a cool black cd with a weird adapter and the ugly console.
                                          A Former User
                                          I can agree here. The famicon/euro one is more sleek while the american is more bulky.
                                          • denisuuD
                                            denisuu @edmaul69
                                            @edmaul69 I was actually not even born when the SNES came out, so I never had one before. I was also very surprised to see there were 2 versions. I do love the old retro gaming machines a lot more then the new ones!
