    Setting per-emulator (or even per-ROM) display driver default in RA
    dispmanx
    5 Posts 5 Posters 1.6k Views
      themyst
      Hi, I would like to know if anyone can assist with this issue.
      I prefer the dispmanx driver because of lower input lag and have no interest in filters, however cocktail format games (e.g. 1942/1943) will not properly rotate to view on my 16:9 screen.
      The only fix is to use the gl driver for proper display rotation, but I would prefer to use that driver for the games that require it, not as my global default.
      I've searched reddit, this forum, retropie documentation, I see nothing pertaining to setting a particular display driver on a per-emulator or per-ROM basis.
      Latest 4.2 build (although this occurred on my 4.1.13 install as well), Rpi 3b, 2.5a Canakit power adapter.
      @Global-Moderators
      mediamogulM BuZzB 2 Replies Last reply Reply Quote -1
        mediamogul Global Moderator @themyst
        @themyst
        You haven't specified what emulator you're using, but assuming that it's a RetroArch core, the link below should help. Specifically the part about ROM-Specfic settings.
        https://github.com/RetroPie/RetroPie-Setup/wiki/RetroArch-Configuration#config-hierarchy
        In your case, you'd want to add:
        video_driver = "gl"
        Also, there are a lot of knowledgeable people here on the forums that are always willing to help. It's bad form to make a global call out to the moderators unless there is an urgent issue to be dealt with.
        • AlexMurphyA
          AlexMurphy Banned
          I hate to be this guy but:
            BuZz administrators @themyst
            @themyst more importantly - do NOT flag groups/people when posting for help - imagine if everyone did that. A bit selfish. I don't need notifications and in fact will ignore people that tag me specifically rather than patiently waiting for an answer.
            • FloobF
              Floob
              @themyst
              This may help:
              https://retropie.org.uk/forum/topic/2199/specific-retroarch-emulator-settings-are-being-over-written-after-i-quit-the-game/24
