    USB Start/Select problems
    usb controlersarcade control
    7 Posts 3 Posters 2.0k Views
    • E
      evarcade85
      Hi Everyone,
      This is only my 2nd post here so please go easy on me. I am currently halfway through my 2 player table top arcade build. Just received the arcade sticks and buttons. They are running through separate USB ports. The problem I am having is that when I map player one's start and select buttons it works fine. When I come to map player 2's the Start and Select buttons on player one swap over. Then when I go back to remap player 1's player 2's swap over. Anyone experienced anything like this before. Hoping it is a simple fix that I just can't see.
      Thank you in advance for your help!
        mediamogul Global Moderator @evarcade85
        @evarcade85
        You'll really need to post more info about your setup first, as detailed below:
        One thing that comes to mind at first blush is that you might have 'save on exit' set in RetroArch.
        • E
          evarcade85
          Oh sorry, my mistake
          Pi Model or other hardware: Raspberrry Pi 3
          Power Supply used: Official Raspberry power supply
          RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.2
          USB Devices connected: USB Hard drive (separate power supply) USB Keyboard
          Controller used:
          Error messages received: none
          How to replicate the problem:
          Hope this helps.
          • AlexMurphyA
            AlexMurphy Banned @evarcade85
            @evarcade85 You haven't included any of the relevant information. Please post ALL of it.
            • E
              evarcade85
              Controller used: USB joystick
              Guide used: I didn't follow any guide
              File: Its the USB joystick I guess
              Emulator: All emulators
              Attachment of config files: I dont know how to post config files and I am using a mac to write this so I dont know how to ssd into my pi.
              How to replicate the problem: Just reconfigure either player one or player two and the other controller will swap the start/select buttons.
              I am so sorry I am not offering any more info. Like I said I am new to this and I was just hoping it was a easy fix. Again, sorry. I dont want to annoy anyone here
              • AlexMurphyA
                @evarcade85 I'm not trying to be rude but the information is asked for a reason. Try this tool. https://github.com/meleu/RetroPie-joystick-selection
                • E
                  evarcade85 @AlexMurphy
                  @AlexMurphy Oh I totally understand. I am just sorry I can't provide more. I tried that git hub link but no luck. I have found a work around that was so simple I am almost ashamed I didn't think of it before. I have just swapped the start/select buttons over on P1. Feeling quite silly now!
                  It is a quirk of the system however. Hopefully my button swapping will last and it wont swap back again once I have put the buttons in the unit.
                  Thank you for all your help!
