    Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!
    musicbgmsynackguide
    165 Posts 59 Posters 125.3k Views
      cyperghost @Alturis
      @Alturis
      I don't want to hijack the thread
      So I created a new BG-Music on Retropie - Post your favourites here
      • coldnpaleC
        coldnpale @vj88
        @vj88 said in Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!:
        I have a problem with this... splash screen won't play over e.s. loading screen! Emulation always starts at splash screen end. I know that the problem is this method cause it doesn't wait without it!
        Anyone else having this issue? Is it normal or can it be avoied?
        • FinnbroF
          Finnbro
          The above scripts are helpful, thanks!
          • BriganeB
            Brigane
            I have a problem getting both mp3 and video snaps playing at the same time. Also the in-game sound is gone.
            I think the reason is that the audio source is busy playing the audio (mp3) and it can not handle the video snaps and mp3 files simultaneously for some reason.
            This also happens when I use your image @dmmarti (Motion Blue V5) with the included background music script. Do you have an idea what I can do?
            I'm using a USB Sound Card such as this one https://www.ebay.com/itm/PC-Win7-Mac-Vista-H1-3D-Virtual-Audio-Sound-Card-Adapter-USB-2-0-7-1-Channel-/152624039538
            Any thoughts?
            Any help or thoughts are much appreciated.
            Systems: Raspberry Pi 0/2/3 Model B+
            Os: RetroPie 4.5
            Frontend: Emulationstation & Attract Mode
            • W
              westleigh77 @TMNTturtlguy
              @tmntturtlguy I had the same thought. It's been a year, thought I'd check in to see if anyone's come up with a solution
              • E
                edwardthehuman
                installed this succesfully, but it mutes the game music/sounds entirely when i enter it. any solution?
                BriganeB 1 Reply Last reply Reply Quote 0
                • BriganeB
                  Brigane @edwardthehuman
                  @edwardthehuman
                  This is kind of the same problem I'm having. Do you use a USB sound card or just HDMI?
                  Os: RetroPie 4.5
                  • Y
                    Yuu
                    @brigane I am facing a similar issue. If I have the background music enabled, all in-game sounds don't work. If disabled, no problems. I am using the 3.5 jack to get sound out. Was there ever a solution?
                    • BriganeB
                      Brigane @Yuu
                      @yuu not that I know of. I thought this would occur to other people as well but that doesn't seem to be the case.
                      Os: RetroPie 4.5
                      • Z
                        zerojay
                        Perhaps something caused by the audio device selected?
                        • BriganeB
                          Brigane @zerojay
                          @zerojay yeah perhaps, but how will I know :)
                          Os: RetroPie 4.5
                          • Z
                            zerojay
                            ...By changing the audio device selected?
                            • Y
                              Yuu
                              I've had it set on either Auto or 3.5, same result; if the background music is enabled, there will be no ingame music. I need to test this with HDMI.
                              Edit: Tested with HDMI w/ HDMI Sound. This only effects the 3.5 jack output; HDMI with sound going to TV works fine.
                              • BriganeB
                                Brigane @Yuu
                                @yuu thank you for clarifying that. Now, if only we knew how to make it work with 3.5mm or a USB sound card for that matter.
                                Os: RetroPie 4.5
                                  mitu Global Moderator @Brigane
                                  @brigane As you noticed earlier, it could be because the 3.5 jack output is not able to play 2 simultaneous audio streams. The solution for this would be to use Dmix (https://alsa.opensrc.org/Dmix) or PulseAudio to do the sound mixing for such configurations.
                                  BriganeB 1 Reply Last reply Reply Quote 1
                                  • BriganeB
                                    Brigane @mitu
                                    @mitu thanks for the link. I would like to try and fix it, but I'm not quite sure how to do it. Linux isn't my strong side.
                                    Os: RetroPie 4.5
                                      steve51184
                                      Hi I'm stuck on step 2 and 4..
                                      step 2 causes this error on boot:
                                      https://i.imgur.com/TD896Nk.jpg
                                      The command must be outdated or something I dunno I copied it perfectly
                                      And step 4 there is no retropie_welcome but above # RETROPIE PROFILE END in the /home/pi/.bashrc not at the end or anywhere?
                                      Would love any help
                                      • Z
                                        zerojay @steve51184
                                        @steve51184 said in Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!:
                                        Would love any help
                                        For step 2, it's not all meant to be on the same line. Everything after done needs to be on a second line.
                                          steve51184 @zerojay
                                          @zerojay
                                          Fixed both errors I should've updated the post ty though.. Any ideas in this: https://retropie.org.uk/forum/post/159736
                                          • H
                                            Hyuma
                                            this is awesome! @MapleStory there is a way to load playlist using some combo with joystick and buttons? I would like to have my playlist loaded only whit a combo or similar.. thanks!
